Giriş
The flash battery provides the power necessary to create the flash. This guide describes how to find and remove this battery in order to install a new one.
Remove the screws from the bottom of the camera using the tri-wing screwdriver.
Three 5.4 mm tri-head screws.
Remove screws from motherboard using the Phillips 00 screwdriver.
Two 2.5 mm widehead Phillips screws
One 3.3 mm #00 Phillips screws
Three 2.5 mm #00 Phillips screws (black screws)
Bir başkası bu kılavuzu tamamladı.
