Ana içeriğe geç
Fujifilm Finepix F10 6.3 MP LCD Replacement
Neye ihtiyacın var
  1. Fujifilm Finepix F10 6.3 MP LCD Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP LCD Replacement: adım 2, 1 resimden 1.
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP LCD Replacement: adım 3, 1 resimden 1.
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP LCD Replacement: adım 4, 3 resimden 1. Fujifilm Finepix F10 6.3 MP LCD Replacement: adım 4, 3 resimden 2. Fujifilm Finepix F10 6.3 MP LCD Replacement: adım 4, 3 resimden 3.
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP LCD Replacement, LCD: adım 5, 1 resimden 1.
    • Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove the fifteen 2.9 mm Phillips #00 screws.
  6. Fujifilm Finepix F10 6.3 MP LCD Replacement: adım 6, 1 resimden 1.
    • Slide casing out using the spudger.
  7. Fujifilm Finepix F10 6.3 MP LCD Replacement: adım 7, 2 resimden 1. Fujifilm Finepix F10 6.3 MP LCD Replacement: adım 7, 2 resimden 2.
    • Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sarah Looper
100 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-4, Benson Spring 2013 Clemson, Team 13-4, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G4
2 Üyeler
16 adet Kılavuz yazıldı
3 Yorum
Great Guide! Worked great to replace my screen!
Daniel - Yanıt
Awesome guide! BEST WORK I'VE EVER SEEN ON A REPAIR GUIDE
Johnston Thayer - Yanıt
Shutter button replacement was great too!
Daniel -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 962
