Giriş
A guide on how to take out the many screws located on the inside, metal cover and how to install an LCD.
Neye ihtiyacın var
Remove the screws from the bottom of the camera using the tri-wing screwdriver.
Three 5.4 mm tri-head screws.
Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
Remove the fifteen 2.9 mm Phillips #00 screws.
Bir başkası bu kılavuzu tamamladı.
3 Yorum
Awesome guide! BEST WORK I'VE EVER SEEN ON A REPAIR GUIDE
Shutter button replacement was great too!
Daniel -
