Ana içeriğe geç
Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement
Neye ihtiyacın var
  1. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: adım 2, 1 resimden 1.
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: adım 3, 1 resimden 1.
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: adım 4, 3 resimden 1. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: adım 4, 3 resimden 2. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: adım 4, 3 resimden 3.
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: adım 5, 2 resimden 1. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement, Lens Filter Set: adım 5, 2 resimden 2.
    • Remove electrowind strip from font cover.
    • The front cover does not have to be separated from the device for this step or the next ones.
  6. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: adım 6, 1 resimden 1.
    • Remove lens data cable by gently pulling it out.
  7. Fujifilm Finepix F10 6.3 MP Lens Filter Set Replacement: adım 7, 1 resimden 1.
    • Remove lens filter.
    • There are multiple square pieces, so be sure to remove them all.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sarah Looper
100 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-4, Benson Spring 2013 Clemson, Team 13-4, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G4
2 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 832
