Ana içeriğe geç
Fujifilm Finepix F10 6.3 MP Lens Replacement
Neye ihtiyacın var
  1. Fujifilm Finepix F10 6.3 MP Lens Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP Lens Replacement: adım 2, 1 resimden 1.
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP Lens Replacement: adım 3, 1 resimden 1.
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP Lens Replacement: adım 4, 3 resimden 1. Fujifilm Finepix F10 6.3 MP Lens Replacement: adım 4, 3 resimden 2. Fujifilm Finepix F10 6.3 MP Lens Replacement: adım 4, 3 resimden 3.
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP Lens Replacement, Front cover: adım 5, 1 resimden 1.
    • Remove screws from motherboard using the Phillips 00 screwdriver.
    • Two 2.5 mm widehead Phillips screws
    • One 3.3 mm #00 Phillips screws
    • Three 2.5 mm #00 Phillips screws (black screws)
  6. Fujifilm Finepix F10 6.3 MP Lens Replacement: adım 6, 1 resimden 1.
    • Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
    • Remove 3.3 mm #00 Phillips screw from the side of the front screen.
  7. Fujifilm Finepix F10 6.3 MP Lens Replacement: adım 7, 2 resimden 1. Fujifilm Finepix F10 6.3 MP Lens Replacement: adım 7, 2 resimden 2.
    • Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard.
    • Do not be alarmed if it takes substantial pressure to separate the two.
  8. Fujifilm Finepix F10 6.3 MP Lens Replacement, Lens: adım 8, 3 resimden 1. Fujifilm Finepix F10 6.3 MP Lens Replacement, Lens: adım 8, 3 resimden 2. Fujifilm Finepix F10 6.3 MP Lens Replacement, Lens: adım 8, 3 resimden 3.
    • Firmly grasp the lens and pull completely from housing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sarah Looper
100 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-4, Benson Spring 2013 Clemson, Team 13-4, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G4
2 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 1,727
