Giriş
Use caution when going through with the procedure. This procedure involves doing operations near the motherboard of the device, which has many sensitive components.
Neye ihtiyacın var
Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
Use a plastic opening tool to lift up the right side of the display screen.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Hi, any idea how i can get to the shutter button mechanism, it’s stopped working and I don’t want to break anything in my impatience to fix it :)
