Ana içeriğe geç
Fujifilm Finepix S1000fd Display Screen Replacement
Neye ihtiyacın var
  1. Fujifilm Finepix S1000fd Display Screen Replacement, Rear Cover Casing: adım 1, 2 resimden 1. Fujifilm Finepix S1000fd Display Screen Replacement, Rear Cover Casing: adım 1, 2 resimden 2.
    • Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
  2. Fujifilm Finepix S1000fd Display Screen Replacement: adım 2, 2 resimden 1. Fujifilm Finepix S1000fd Display Screen Replacement: adım 2, 2 resimden 2.
    • Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
    • Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
  3. Fujifilm Finepix S1000fd Display Screen Replacement: adım 3, 1 resimden 1.
    • Once you unscrew all of the screws, carefully remove the rear casing.
    • Be careful not to pull the rear casing, otherwise you will rip the ribbon cable.
    • Detach the ribbon cable by lifting the tab on the connector.
  4. Fujifilm Finepix S1000fd Display Screen Replacement, Display Screen: adım 4, 1 resimden 1.
    • Use a plastic opening tool to lift up the right side of the display screen.
  5. Fujifilm Finepix S1000fd Display Screen Replacement: adım 5, 1 resimden 1.
    • Once the screen is out, you will realize that it is still connected to the ribbon cable. To unplug this ribbon cable, use a plastic opening tool to pull up and to the left on the ribbon cable connector and release the ribbon cable.
  6. Fujifilm Finepix S1000fd Display Screen Replacement: adım 6, 1 resimden 1.
    • Using your PH00 screwdriver, unscrew the 0.5mm screw located on the bottom left hand corner where the display screen used to be.
  7. Fujifilm Finepix S1000fd Display Screen Replacement: adım 7, 1 resimden 1.
    • Use the PH00 screwdriver to unscrew the 0.5mm screws located near the top left corner, top right corner, and bottom right corner.
  8. Fujifilm Finepix S1000fd Display Screen Replacement: adım 8, 1 resimden 1.
    • Lift up the gray component where the display screen use to sit in.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lizzie Eller
422 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-7, Banghart Winter 2017 Cal Poly, Team 8-7, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G7
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Hi, any idea how i can get to the shutter button mechanism, it’s stopped working and I don’t want to break anything in my impatience to fix it :)
mike.osupe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 905
