Ana içeriğe geç
Fujifilm Finepix S1000fd Rear Cover Casing Replacement
Neye ihtiyacın var
  1. Fujifilm Finepix S1000fd Rear Cover Casing Replacement, Rear Cover Casing: adım 1, 2 resimden 1. Fujifilm Finepix S1000fd Rear Cover Casing Replacement, Rear Cover Casing: adım 1, 2 resimden 2.
    • Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
  2. Fujifilm Finepix S1000fd Rear Cover Casing Replacement: adım 2, 2 resimden 1. Fujifilm Finepix S1000fd Rear Cover Casing Replacement: adım 2, 2 resimden 2.
    • Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
    • Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
  3. Fujifilm Finepix S1000fd Rear Cover Casing Replacement: adım 3, 1 resimden 1.
    • Once you unscrew all of the screws, carefully remove the rear casing.
    • Be careful not to pull the rear casing, otherwise you will rip the ribbon cable.
    • Detach the ribbon cable by lifting the tab on the connector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lizzie Eller
422 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-7, Banghart Winter 2017 Cal Poly, Team 8-7, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G7
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 590
