Ana içeriğe geç
Fujifilm Finepix S1800 Back Cover Assembly Replacement
Neye ihtiyacın var
  1. Fujifilm Finepix S1800 Back Cover Assembly Replacement, Back Cover Assembly: adım 1, 1 resimden 1.
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Back Cover Assembly Replacement: adım 2, 1 resimden 1.
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Back Cover Assembly Replacement: adım 3, 1 resimden 1.
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Back Cover Assembly Replacement: adım 4, 2 resimden 1. Fujifilm Finepix S1800 Back Cover Assembly Replacement: adım 4, 2 resimden 2.
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Rockford
618 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-6, Eyestone Spring 2017 USF Tampa, Team 8-6, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S8G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 443
