Ana içeriğe geç
Fujifilm Instax 100 Disassembly
Neye ihtiyacın var
  1. Fujifilm Instax 100 Disassembly, Fujifilm Instax 100 Disassembly: adım 1, 1 resimden 1.
    • First, push on the recessed part of the battery cover while sliding it away from the camera to remove it. Then, remove all the batteries from the camera.
  2. Fujifilm Instax 100 Disassembly: adım 2, 1 resimden 1.
    • Make sure to remove the batteries if you plan to store the camera or if you don't use it anymore. Otherwise your battery compartment will end up looking like mine.
    • Undo the 2 small Phillips screws at the top of the battery compartment.
    • Next, undo the 2 medium sized Phillips screws recessed into the compartment, that are circled in yellow in the photo.
  3. Fujifilm Instax 100 Disassembly: adım 3, 2 resimden 1. Fujifilm Instax 100 Disassembly: adım 3, 2 resimden 2.
    • Undo the 2 long Phillips screws located on the handles that hold the strap.
    • Next, undo the 2 short Phillips screws on the bottom of the camera. These are all the screws you will have to remove in order to pull the case apart.
  4. Fujifilm Instax 100 Disassembly: adım 4, 2 resimden 1. Fujifilm Instax 100 Disassembly: adım 4, 2 resimden 2.
    • Start pulling the 2 halves of the case apart very slowly, while facing the bottom of the camera.
    • Watch out for the fragile ribbon cable! Do not try to pull the 2 halves completely apart until you disconnect it.
    • Using both hands, pull the connector tab up gently while pulling the ribbon away slowly, so that you don't damage it, as shown in the second photo.
  5. Fujifilm Instax 100 Disassembly: adım 5, 1 resimden 1.
    • Do not touch the areas circled in yellow until you discharge the capacitor on the left unless you want to get shocked.
    • To discharge the capacitor, you will have to touch its two metal feet simultaneously, for a fraction of a second or more, with something like a large flat head screwdriver. To avoid touching other components while doing this, which can be harmful, you can cover the metal shaft of the screwdriver in tape, except for the tip that will short the feet.
    • When you discharge the capacitor, you will probably hear a loud bang and sparks could form between it and the screwdriver. This is normal and will not damage your camera as long as your screwdriver is ONLY touching the feet of the capacitor.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sample Text
276 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
If the flash capacitor discharges, does that mean my flash not working likely has to do with the bulb needing replacement instead of the flash capacitor needing replacement? I have an instax wide 300 and had only snapped 40 pictures and I started to realize the flash never came on when I felt it should have. I waited too long to send to fujifilm for a warranty replacement and now a repair costs almost as much as buying a new one
Mark - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 37
Son 30 gün: 142
Her zaman: 6,907
