Ana içeriğe geç
Fujifilm Instax Mini 70 Shell Replacement
Neye ihtiyacın var
  1. Fujifilm Instax Mini 70 Shell Replacement, Shell: adım 1, 2 resimden 1. Fujifilm Instax Mini 70 Shell Replacement, Shell: adım 1, 2 resimden 2.
    • Look at the bottom of the camera and find the four 6 mm Phillips #0 screws and remove them.
  2. Fujifilm Instax Mini 70 Shell Replacement: adım 2, 3 resimden 1. Fujifilm Instax Mini 70 Shell Replacement: adım 2, 3 resimden 2. Fujifilm Instax Mini 70 Shell Replacement: adım 2, 3 resimden 3.
    • Use a jimmy to separate the front and back shells. Then, use your hands to gently pull the back shell away from the front until it fully detaches.
  3. Fujifilm Instax Mini 70 Shell Replacement: adım 3, 2 resimden 1. Fujifilm Instax Mini 70 Shell Replacement: adım 3, 2 resimden 2.
    • At the top of the camera, locate the 8 mm Phillips #0 screw and remove it.
  4. Fujifilm Instax Mini 70 Shell Replacement: adım 4, 3 resimden 1. Fujifilm Instax Mini 70 Shell Replacement: adım 4, 3 resimden 2. Fujifilm Instax Mini 70 Shell Replacement: adım 4, 3 resimden 3.
    • Use your hands to gently pull the front shell off of the camera.
Sonuç
Jaime Arriaga
109 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 143
