Ana içeriğe geç
Fujifilm Instax Mini 8 Flash Unit Replacement
Neye ihtiyacın var
  1. Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: adım 1, 2 resimden 1. Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: adım 1, 2 resimden 2.
    • You start off with the camera.
  2. Fujifilm Instax Mini 8 Flash Unit Replacement: adım 2, 2 resimden 1. Fujifilm Instax Mini 8 Flash Unit Replacement: adım 2, 2 resimden 2.
    • Open up the back and remove the film cartridge.
  3. Fujifilm Instax Mini 8 Flash Unit Replacement: adım 3, 2 resimden 1. Fujifilm Instax Mini 8 Flash Unit Replacement: adım 3, 2 resimden 2.
    • Remove the two Phillips #00 screws from the bottom of the camera.
    • Remove the two screws on the side of the camera.
    • Additionally, there are two screws in the battery compartment which also need to be removed.
  4. Fujifilm Instax Mini 8 Flash Unit Replacement: adım 4, 3 resimden 1. Fujifilm Instax Mini 8 Flash Unit Replacement: adım 4, 3 resimden 2. Fujifilm Instax Mini 8 Flash Unit Replacement: adım 4, 3 resimden 3.
    • Once all screws are removed, gently pry open the front casing with your hands or a prying tool.
    • There will be a spring that attaches the front casing and the main circuit board, so take care as to not break the spring.
  5. Fujifilm Instax Mini 8 Flash Unit Replacement: adım 5, 1 resimden 1.
    • You should now be able to see the flash unit. Take care to not touch the large black capacitor on the top. It will still have a charge and will hurt.
  6. Fujifilm Instax Mini 8 Flash Unit Replacement: adım 6, 2 resimden 1. Fujifilm Instax Mini 8 Flash Unit Replacement: adım 6, 2 resimden 2.
    • Unscrew the two screws attaching the flash to the main circuit board. The flash unit will detach away from the motherboard, now leaving just the connecting wires to remove next.
  7. Fujifilm Instax Mini 8 Flash Unit Replacement: adım 7, 3 resimden 1. Fujifilm Instax Mini 8 Flash Unit Replacement: adım 7, 3 resimden 2. Fujifilm Instax Mini 8 Flash Unit Replacement: adım 7, 3 resimden 3.
    • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Bo W
1.010 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Meier Fall 2015 USF Tampa, Team 4-1, Meier Fall 2015 üyesi
USFT-MEIER-F15S4G1
4 Üyeler
26 adet Kılavuz yazıldı
10Kılavuz Yorumları
Where can I purchase the flash unit?
Casey Sanders - Yanıt
Hi, did you ever find out where to replace the flash light unit?
Rachel Street -
Why is all the camera lights flashing red and doesn't work?
medgabby - Yanıt
Will the camera work without any flash, or are the connections required for the whole thing to function ?
Hyaku Gen - Yanıt
Where can I find the flash unit to purchase??
Maria - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 35
Son 30 gün: 184
Her zaman: 36,243
