Ana içeriğe geç
Fujifilm Instax Mini Eight Camera Shell Replacement
Neye ihtiyacın var
    1. Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: adım 1, 3 resimden 1. Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: adım 1, 3 resimden 2. Fujifilm Instax Mini Eight Camera Shell Replacement, Camera Shell: adım 1, 3 resimden 3.
      • Start off by looking at your camera and rotating it to locate all the screws. There should be nine screws in all.
      • One screw is hidden below the oval plastic cover of printers opening. Remove the cover to unveil the ninth screw.
      FixBot'a Sor
      Yorum Ekle
    2. Fujifilm Instax Mini Eight Camera Shell Replacement: adım 2, 3 resimden 1. Fujifilm Instax Mini Eight Camera Shell Replacement: adım 2, 3 resimden 2. Fujifilm Instax Mini Eight Camera Shell Replacement: adım 2, 3 resimden 3.
      • Press the tab down in order to unlatch the film compartment cover.
      • Remove the film from the compartment (if any is present)
      • Remove the compartment cover completely.
      • Begin by using the small #00 Philips head screwdriver and turning at a counter-clockwise fashion to remove screws.
      FixBot'a Sor
      Yorum Ekle
    3. Fujifilm Instax Mini Eight Camera Shell Replacement: adım 3, 3 resimden 1. Fujifilm Instax Mini Eight Camera Shell Replacement: adım 3, 3 resimden 2. Fujifilm Instax Mini Eight Camera Shell Replacement: adım 3, 3 resimden 3.
      • Use the plastic opening tools and spudger to safely remove the front shell casing.
      FixBot'a Sor
      Yorum Ekle
    4. Fujifilm Instax Mini Eight Camera Shell Replacement: adım 4, 2 resimden 1. Fujifilm Instax Mini Eight Camera Shell Replacement: adım 4, 2 resimden 2.
      • Lift the front part of shell up, assuring not to pull too hard due a spring that is connect to the shell and the inside of the camera.
      • Carefully, using a small #00 Philips head screwdriver, remove the spring from the inside component of the camera.
      • At this point you should have the shell removed completely. Congratulations! Repeat the steps backwards to get the shell back on your camera unit.
      FixBot'a Sor
      Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Bo W
1.052 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Meier Fall 2015 USF Tampa, Team 4-1, Meier Fall 2015 üyesi
USFT-MEIER-F15S4G1
4 Üyeler
26 adet Kılavuz yazıldı
19Kılavuz Yorumları
For removing initial screws, there are 9 screws. The 9th screw is under the cover overlying the exit of the Polaroid film area. (hidden under the cover)
princesslsy - Yanıt Paylaş
but where near the exit? i cannot find it
Emily Birkler - Yanıt Paylaş
It's at the top of the camera where you get picture.
xxx - Yanıt Paylaş
I need the circular yellow plastic piece that goes around the lens. How can I obtain that? How do I attach?
jason81173 - Yanıt Paylaş
I've drop my instax mini 8 at the airport and it looks perfectly fine at first until I realized that the film compartment has broken and it can't close its 'door', but the instax still can be use just need to press the door against the film everytime I used which is annoying. Does anyone know how to fix it?
Siti Syuhanna hussein - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 44
Son 30 gün: 199
Her zaman: 71,329
