Ana içeriğe geç
Fujifilm Instax Minion Motor Replacement
Neye ihtiyacın var
  1. Fujifilm Instax Minion Motor Replacement, Camera Shell: adım 1, 3 resimden 1. Fujifilm Instax Minion Motor Replacement, Camera Shell: adım 1, 3 resimden 2. Fujifilm Instax Minion Motor Replacement, Camera Shell: adım 1, 3 resimden 3.
    • Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
  2. Fujifilm Instax Minion Motor Replacement: adım 2, 3 resimden 1. Fujifilm Instax Minion Motor Replacement: adım 2, 3 resimden 2. Fujifilm Instax Minion Motor Replacement: adım 2, 3 resimden 3.
    • Use a spudger to remove the film slot guard on the top of the camera.
    • Remove the one 4.5 mm #00 Phillips screw under the slot guard.
  3. Fujifilm Instax Minion Motor Replacement: adım 3, 3 resimden 1. Fujifilm Instax Minion Motor Replacement: adım 3, 3 resimden 2. Fujifilm Instax Minion Motor Replacement: adım 3, 3 resimden 3.
    • Press the release tab on the back of the camera to open the film compartment.
    • Remove the film cartridge within this compartment.
  4. Fujifilm Instax Minion Motor Replacement: adım 4, 3 resimden 1. Fujifilm Instax Minion Motor Replacement: adım 4, 3 resimden 2. Fujifilm Instax Minion Motor Replacement: adım 4, 3 resimden 3.
    • Press the battery cover in and down to remove it.
    • Remove any batteries within.
  5. Fujifilm Instax Minion Motor Replacement: adım 5, 3 resimden 1. Fujifilm Instax Minion Motor Replacement: adım 5, 3 resimden 2. Fujifilm Instax Minion Motor Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to help pry the front and back shells apart.
    • With the camera facing down, remove only the back shell.
  6. Fujifilm Instax Minion Motor Replacement: adım 6, 3 resimden 1. Fujifilm Instax Minion Motor Replacement: adım 6, 3 resimden 2. Fujifilm Instax Minion Motor Replacement: adım 6, 3 resimden 3.
    • Carefully peel the front side of the shell away.
    • As you lift the front shell, be careful to not pull too hard since there is a spring attached to the shell and the camera body.
    • Using a set of tweezers, detach the spring from the body. The spring will retract into the black and gray ring on the front shell.
  7. Fujifilm Instax Minion Motor Replacement, Motor: adım 7, 2 resimden 1. Fujifilm Instax Minion Motor Replacement, Motor: adım 7, 2 resimden 2.
    • Remove the four 4.5 mm #00 Phillips screws on the battery compartment.
  8. Fujifilm Instax Minion Motor Replacement: adım 8, 1 resimden 1.
    • Lift up the battery compartment to free up the motor.
  9. Fujifilm Instax Minion Motor Replacement: adım 9, 1 resimden 1.
    • Unscrew the two 2.9mm Phillips #00 screws holding the motor to the frame.
  10. Fujifilm Instax Minion Motor Replacement: adım 10, 2 resimden 1. Fujifilm Instax Minion Motor Replacement: adım 10, 2 resimden 2.
    • Remove the motor from the frame.
  11. Fujifilm Instax Minion Motor Replacement: adım 11, 2 resimden 1. Fujifilm Instax Minion Motor Replacement: adım 11, 2 resimden 2.
    • Desolder the wires from the leads of the capacitor.
    • Take note of the connections between the wires and leads for reassembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jeffery
220 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G6, Livingston Spring 2018 Cal Poly, Team S18-G6, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S18G6
4 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
Can anyone help finding a motor for the instax 8 or 9? I can't find one to fit any help appreciated
Jordan Kelly - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 24
Her zaman: 1,356
