Ana içeriğe geç
Fujifilm X30 Lens Replacement
Neye ihtiyacın var
    1. Fujifilm X30 Lens Replacement, Battery: adım 1, 2 resimden 1. Fujifilm X30 Lens Replacement, Battery: adım 1, 2 resimden 2.
      • Turn the camera upside down.
      • Place your thumb on the switch, and slide it towards the center of the camera.
      • The compartment will pop open.
      FixBot'a Sor
      Yorum Ekle
    2. Fujifilm X30 Lens Replacement: adım 2, 1 resimden 1.
      • Once you have the battery compartment open, slide the orange tab away from the battery until it ejects.
      FixBot'a Sor
      Yorum Ekle
    3. Fujifilm X30 Lens Replacement: adım 3, 1 resimden 1.
      • Pull the battery out.
      FixBot'a Sor
      Yorum Ekle
    1. Fujifilm X30 Lens Replacement, Lens: adım 4, 3 resimden 1. Fujifilm X30 Lens Replacement, Lens: adım 4, 3 resimden 2. Fujifilm X30 Lens Replacement, Lens: adım 4, 3 resimden 3.
      • Begin by removing the outside screws using a Phillips #000 Screwdriver:
      • Remove the three 3.6 mm silver screws located on the bottom of the camera.
      • Remove all four of the 4.7 mm screws from the sides of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Fujifilm X30 Lens Replacement: adım 5, 2 resimden 1. Fujifilm X30 Lens Replacement: adım 5, 2 resimden 2.
      • Remove all screws listed below using a Phillips #000 Screwdriver:
      • Lift up the screen and remove the two 4.5 mm screws located in the bottom corners.
      • Remove the 4.0 mm screw that is located behind the screen and directly under the eye piece.
      FixBot'a Sor
      Yorum Ekle
    3. Fujifilm X30 Lens Replacement: adım 6, 1 resimden 1.
      • Carefully remove the bottom piece of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Fujifilm X30 Lens Replacement: adım 7, 1 resimden 1.
      • Do not pull hard when removing the backing because it could rip the orange strip attached to the motherboard.
      • Gently pull off the back of the camera from the left side so that it is partially open.
      • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it
      • Refer to the next step to see pictures of how to properly use the spudger when removing a strip.
      FixBot'a Sor
      Yorum Ekle
    5. Fujifilm X30 Lens Replacement: adım 8, 3 resimden 1. Fujifilm X30 Lens Replacement: adım 8, 3 resimden 2. Fujifilm X30 Lens Replacement: adım 8, 3 resimden 3.
      • For all five indicated orange strips:
      • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it.
      FixBot'a Sor
      Yorum Ekle
    6. Fujifilm X30 Lens Replacement: adım 9, 1 resimden 1.
      • For the final orange strip located behind the top strip:
      FixBot'a Sor
      Yorum Ekle
    7. Fujifilm X30 Lens Replacement: adım 10, 3 resimden 1. Fujifilm X30 Lens Replacement: adım 10, 3 resimden 2. Fujifilm X30 Lens Replacement: adım 10, 3 resimden 3.
      • Remove the two 3.4 mm screws at the bottom of the silver plate.
      • Peel back the clear strip to reveal a 2.8 mm screw on the left of the silver plate and remove it.
      • Peel back the copper plate.
      FixBot'a Sor
      Yorum Ekle
    8. Fujifilm X30 Lens Replacement: adım 11, 1 resimden 1.
      • Remove the three 2.6 mm screws located in the top two corners and the bottom right corner of the motherboard using a Phillips #000 Screwdriver.
      • Lift the motherboard so it is out of your way to remove the lens.
      • You do not need to desolder the motherboard to reach the lens.
      FixBot'a Sor
      Yorum Ekle
    9. Fujifilm X30 Lens Replacement: adım 12, 1 resimden 1.
      • Remove the four 4.4 mm silver screws at the corners of the lens using a Phillips #000 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    10. Fujifilm X30 Lens Replacement: adım 13, 2 resimden 1. Fujifilm X30 Lens Replacement: adım 13, 2 resimden 2.
      • Pull the lens down so it can clear the silver tab.
      • Then push the lens with your index fingers from the front of the camera until it is removed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Haley Moss
370 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 70-3, Forte Winter 2016 Cal Poly, Team 70-3, Forte Winter 2016 üyesi
CPSU-FORTE-W16S70G3
5 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 52
Her zaman: 6,198
