Giriş
Use this guide if the rear case is cracked or broken and needs to be replaced. Replacing the rear case requires removing of screws which may be difficult if they are stripped.
Neye ihtiyacın var
Using a 1.5mm Hex Screwdriver, remove the two 3.0 mm hex screws on the front of the camera.
Using a Phillips #00 screwdriver, remove the two 3.0 mm screws on the bottom of the front face.
Neredeyse bitti!
Sonuç
