Ana içeriğe geç
Giriş
Replacing the hard drive for the Fujitsu Lifebook U810 can be a simple process if directions are followed carefully. The only tool required is a Phillips head +J0 sized screwdriver to remove the Phillips screws on the back of the LifeBook. This guide improves the memory and speed of the device. You can find a new hard drive online by searching the model number and corresponding part for the U810 model.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver. Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver. Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver.
    • Remove back cover of the device by unscrewing the four 7mm screws with a Phillips #0 screwdriver.
  2. Dizüstü Bilgisayar Bataryaları
    An easy fix for a big power boost.
    Hemen Alışveriş Yapın
  3. Remove the two 5mm screws with a Phillips #0 screwdriver. Remove the hard drive from the LifeBook. Remove the hard drive from the LifeBook.
    • Remove the two 5mm screws with a Phillips #0 screwdriver.
    • Remove the hard drive from the LifeBook.
  4. Detach the two wires connected to the hard drive by gently pulling them out of place. Detach the two wires connected to the hard drive by gently pulling them out of place.
    • Detach the two wires connected to the hard drive by gently pulling them out of place.
Sonuç
Anne Kutt
197 İtibar
1 Kılavuz yazıldı
Takım
UC Davis, Team S4-G7, Lore Fall 2018 UC Davis, Team S4-G7, Lore Fall 2018 üyesi
UCD-LORE-F18S4G7
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 4
Son 30 Gün: 6
Her zaman: 105
