Giriş
This guide will help you change HDD in your laptop. REMEMBER! You're doing it at your own risk! However, it's easy. Just take your time, keep thing organized.
Neye ihtiyacın var
Turn your notebook over.
For safety reasons, remove battery. Pull switch on the right inwards. Do the same with the one on left side. Hold it, then pull out the battery.
Now remove screw holding HDD cover.
Remove cover by pulling upwards form left.
Pull HDD holder to the left by its ribbon. Now you can lift up your HDD.
To remove HDD from its holder, remove 4 screws on both sides of HDD holder.
