Ana içeriğe geç
Fujitsu LIFEBOOK P7010D Monitor Replacement
Neye ihtiyacın var
  1. Fujitsu LIFEBOOK P7010D Monitor Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop upside down on a table.
    FixBot'a Sor
    Yorum Ekle
  2. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 2, 1 resimden 1.
    • Locate the battery (the grey block). Find the two tabs on one end of the battery, as pictured.
    • Using two fingers, press both tabs down at once until they are fully depressed.
    FixBot'a Sor
    Yorum Ekle
  3. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 3, 1 resimden 1.
    • While holding the tabs down, slowly pivot the battery up.
    • The battery is now free and safe to pull out.
    FixBot'a Sor
    Yorum Ekle
  4. Fujitsu LIFEBOOK P7010D Monitor Replacement, Keyboard: adım 4, 2 resimden 1. Fujitsu LIFEBOOK P7010D Monitor Replacement, Keyboard: adım 4, 2 resimden 2.
    • Unscrew three 2.4mm and one 5.7mm screws using a Phillips # 0.
    • Unscrew three 1.9mm screws in the battery compartment still using a Phillips # 0
    FixBot'a Sor
    Yorum Ekle
  5. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 5, 3 resimden 1. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 5, 3 resimden 2. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 5, 3 resimden 3.
    • Mind the wire connections on the bottom right side of the monitor. They are still connected between the monitor and computer.
    • Raise the monitor as you normally would until it pops out by itself. Rotate the left side up and to the right to unhook hinges that may catch on the computer.
    • Lay the monitor flat next to the computer.
    FixBot'a Sor
    Yorum Ekle
  6. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 6, 2 resimden 1. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Using a smaller spudger (like a PX3688), pivot the sound case out above the "F2" and "Insert" buttons.
    • Lift the case out and set it aside.
    • For the proceeding steps, put on your anti-static wrist strap and attach the metal clip to something metal and grounded in order to protect the delicate circuitry inside the computer.
    FixBot'a Sor
    Yorum Ekle
  7. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 7, 3 resimden 1. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 7, 3 resimden 2. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 7, 3 resimden 3.
    • Using the same spudger, pry the top of the keyboard up above the "F2" key.
    • Turn the computer so that the bottom is facing you.
    • The keyboard is connected to a black plastic strip, slowly pull the keyboard and place it to the side.
    FixBot'a Sor
    Yorum Ekle
  8. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 8, 2 resimden 1. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 8, 2 resimden 2.
    • Disconnect the keyboard by gently pulling on the hard plastic square straight up from the white connector.
    FixBot'a Sor
    Yorum Ekle
  9. Fujitsu LIFEBOOK P7010D Monitor Replacement, Monitor: adım 9, 3 resimden 1. Fujitsu LIFEBOOK P7010D Monitor Replacement, Monitor: adım 9, 3 resimden 2. Fujitsu LIFEBOOK P7010D Monitor Replacement, Monitor: adım 9, 3 resimden 3.
    • Peel the white tape from the wires connected to the monitor, but do not completely remove it.
    • Unplug the white and black wires with your fingers.
    FixBot'a Sor
    Yorum Ekle
  10. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 10, 3 resimden 1. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 10, 3 resimden 2. Fujitsu LIFEBOOK P7010D Monitor Replacement: adım 10, 3 resimden 3.
    • Unplug the white chip connected to the thicker wire with two smaller spudgers (like a PX3688) by wiggling it back and forth until it pops out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicholas Ross
207 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-31, Amido Winter 2012 Cal Poly, Team 10-31, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S10G31
5 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 3,420
