Ana içeriğe geç
Fujitsu LifeBook N3510 Display Replacement
Neye ihtiyacın var
  1. Fujitsu LifeBook N3510 Display Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Display Replacement: adım 2, 1 resimden 1.
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Display Replacement, Hinge Cover: adım 3, 3 resimden 1. Fujitsu LifeBook N3510 Display Replacement, Hinge Cover: adım 3, 3 resimden 2. Fujitsu LifeBook N3510 Display Replacement, Hinge Cover: adım 3, 3 resimden 3.
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Display Replacement: adım 4, 1 resimden 1.
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Display Replacement: adım 5, 3 resimden 1. Fujitsu LifeBook N3510 Display Replacement: adım 5, 3 resimden 2. Fujitsu LifeBook N3510 Display Replacement: adım 5, 3 resimden 3.
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Display Replacement: adım 6, 2 resimden 1. Fujitsu LifeBook N3510 Display Replacement: adım 6, 2 resimden 2.
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Display Replacement: adım 7, 2 resimden 1. Fujitsu LifeBook N3510 Display Replacement: adım 7, 2 resimden 2.
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
  8. Fujitsu LifeBook N3510 Display Replacement, Keyboard: adım 8, 3 resimden 1. Fujitsu LifeBook N3510 Display Replacement, Keyboard: adım 8, 3 resimden 2. Fujitsu LifeBook N3510 Display Replacement, Keyboard: adım 8, 3 resimden 3.
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
  9. Fujitsu LifeBook N3510 Display Replacement: adım 9, 2 resimden 1. Fujitsu LifeBook N3510 Display Replacement: adım 9, 2 resimden 2.
    • Use a spudger to release the ribbon cable from the motherboard.
  10. Fujitsu LifeBook N3510 Display Replacement: adım 10, 2 resimden 1. Fujitsu LifeBook N3510 Display Replacement: adım 10, 2 resimden 2.
    • After the ribbon has been detached, carefully remove the keyboard.
  11. Fujitsu LifeBook N3510 Display Replacement, Metal Motherboard Cover: adım 11, 1 resimden 1.
    • Remove the following screws, all labeled "3."
    • Two 8.63mm screws.
    • One 7.65mm screw.
    • One 5.74mm screw.
    • Remove the following screw, labeled "15."
    • One 17.81mm screw.
  12. Fujitsu LifeBook N3510 Display Replacement: adım 12, 3 resimden 1. Fujitsu LifeBook N3510 Display Replacement: adım 12, 3 resimden 2. Fujitsu LifeBook N3510 Display Replacement: adım 12, 3 resimden 3.
    • Lift the cover with fingers and remove.
  13. Fujitsu LifeBook N3510 Display Replacement, Display: adım 13, 1 resimden 1.
    • Remove labeled screws.
  14. Fujitsu LifeBook N3510 Display Replacement: adım 14, 1 resimden 1.
    • Remove the screws from the bottom of the hinge as shown in the image.
  15. Fujitsu LifeBook N3510 Display Replacement: adım 15, 3 resimden 1. Fujitsu LifeBook N3510 Display Replacement: adım 15, 3 resimden 2. Fujitsu LifeBook N3510 Display Replacement: adım 15, 3 resimden 3.
    • Use a spudger to detach and remove cables from the motherboard.
  16. Fujitsu LifeBook N3510 Display Replacement: adım 16, 3 resimden 1. Fujitsu LifeBook N3510 Display Replacement: adım 16, 3 resimden 2. Fujitsu LifeBook N3510 Display Replacement: adım 16, 3 resimden 3.
    • Unplug highlighted cables from the wireless module.
  17. Fujitsu LifeBook N3510 Display Replacement: adım 17, 3 resimden 1. Fujitsu LifeBook N3510 Display Replacement: adım 17, 3 resimden 2. Fujitsu LifeBook N3510 Display Replacement: adım 17, 3 resimden 3.
    • Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Neil Daniels
1.411 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-18, Amido Winter 2011 Cal Poly, Team 5-18, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S5G18
3 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 4,475
