Ana içeriğe geç
Fujitsu LifeBook N3510 Fan Replacement
Neye ihtiyacın var
  1. Fujitsu LifeBook N3510 Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the two clips on the bottom of the computer that support the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Fujitsu LifeBook N3510 Fan Replacement: adım 2, 1 resimden 1.
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
    FixBot'a Sor
    Yorum Ekle
  3. Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: adım 3, 3 resimden 1. Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: adım 3, 3 resimden 2. Fujitsu LifeBook N3510 Fan Replacement, Hinge Cover: adım 3, 3 resimden 3.
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
    FixBot'a Sor
    Yorum Ekle
  4. Fujitsu LifeBook N3510 Fan Replacement: adım 4, 1 resimden 1.
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
    FixBot'a Sor
    Yorum Ekle
  5. Fujitsu LifeBook N3510 Fan Replacement: adım 5, 3 resimden 1. Fujitsu LifeBook N3510 Fan Replacement: adım 5, 3 resimden 2. Fujitsu LifeBook N3510 Fan Replacement: adım 5, 3 resimden 3.
    • Use a spudger to partially lift the hinge cover.
    FixBot'a Sor
    Yorum Ekle
  6. Fujitsu LifeBook N3510 Fan Replacement: adım 6, 2 resimden 1. Fujitsu LifeBook N3510 Fan Replacement: adım 6, 2 resimden 2.
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  7. Fujitsu LifeBook N3510 Fan Replacement: adım 7, 2 resimden 1. Fujitsu LifeBook N3510 Fan Replacement: adım 7, 2 resimden 2.
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
    FixBot'a Sor
    Yorum Ekle
  8. Fujitsu LifeBook N3510 Fan Replacement, Keyboard: adım 8, 3 resimden 1. Fujitsu LifeBook N3510 Fan Replacement, Keyboard: adım 8, 3 resimden 2. Fujitsu LifeBook N3510 Fan Replacement, Keyboard: adım 8, 3 resimden 3.
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  9. Fujitsu LifeBook N3510 Fan Replacement: adım 9, 2 resimden 1. Fujitsu LifeBook N3510 Fan Replacement: adım 9, 2 resimden 2.
    • Use a spudger to release the ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  10. Fujitsu LifeBook N3510 Fan Replacement: adım 10, 2 resimden 1. Fujitsu LifeBook N3510 Fan Replacement: adım 10, 2 resimden 2.
    • After the ribbon has been detached, carefully remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
  11. Fujitsu LifeBook N3510 Fan Replacement, Metal Motherboard Cover: adım 11, 1 resimden 1.
    • Remove the following screws, all labeled "3."
    • Two 8.63mm screws.
    • One 7.65mm screw.
    • One 5.74mm screw.
    • Remove the following screw, labeled "15."
    • One 17.81mm screw.
    FixBot'a Sor
    Yorum Ekle
  12. Fujitsu LifeBook N3510 Fan Replacement: adım 12, 3 resimden 1. Fujitsu LifeBook N3510 Fan Replacement: adım 12, 3 resimden 2. Fujitsu LifeBook N3510 Fan Replacement: adım 12, 3 resimden 3.
    • Lift the cover with fingers and remove.
    FixBot'a Sor
    Yorum Ekle
  13. Fujitsu LifeBook N3510 Fan Replacement, Fan: adım 13, 3 resimden 1. Fujitsu LifeBook N3510 Fan Replacement, Fan: adım 13, 3 resimden 2. Fujitsu LifeBook N3510 Fan Replacement, Fan: adım 13, 3 resimden 3.
    • Detach fan cable from motherboard.
    FixBot'a Sor
    Yorum Ekle
  14. Fujitsu LifeBook N3510 Fan Replacement: adım 14, 1 resimden 1.
    • Remove labeled screws.
    FixBot'a Sor
    Yorum Ekle
  15. Fujitsu LifeBook N3510 Fan Replacement: adım 15, 2 resimden 1. Fujitsu LifeBook N3510 Fan Replacement: adım 15, 2 resimden 2.
    • Remove fan.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Neil Daniels
1.411 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-18, Amido Winter 2011 Cal Poly, Team 5-18, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S5G18
3 Üyeler
23 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 4,419
