Ana içeriğe geç
Fujitsu LifeBook N3510 Hinge Cover Replacement
Neye ihtiyacın var
  1. Fujitsu LifeBook N3510 Hinge Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Hinge Cover Replacement: adım 2, 1 resimden 1.
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Hinge Cover Replacement, Hinge Cover: adım 3, 3 resimden 1. Fujitsu LifeBook N3510 Hinge Cover Replacement, Hinge Cover: adım 3, 3 resimden 2. Fujitsu LifeBook N3510 Hinge Cover Replacement, Hinge Cover: adım 3, 3 resimden 3.
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Hinge Cover Replacement: adım 4, 1 resimden 1.
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Hinge Cover Replacement: adım 5, 3 resimden 1. Fujitsu LifeBook N3510 Hinge Cover Replacement: adım 5, 3 resimden 2. Fujitsu LifeBook N3510 Hinge Cover Replacement: adım 5, 3 resimden 3.
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Hinge Cover Replacement: adım 6, 2 resimden 1. Fujitsu LifeBook N3510 Hinge Cover Replacement: adım 6, 2 resimden 2.
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Hinge Cover Replacement: adım 7, 2 resimden 1. Fujitsu LifeBook N3510 Hinge Cover Replacement: adım 7, 2 resimden 2.
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
Sonuç
Neil Daniels
1.411 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-18, Amido Winter 2011 Cal Poly, Team 5-18, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S5G18
3 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 3,434
