Ana içeriğe geç
Fujitsu Lifebook A6110 RAM Replacement
Neye ihtiyacın var
    1. Fujitsu Lifebook A6110 RAM Replacement, Battery: adım 1, 2 resimden 1. Fujitsu Lifebook A6110 RAM Replacement, Battery: adım 1, 2 resimden 2.
      • The computer should be fully turned off and disconnected from the power source.
      • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
      • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
      FixBot'a Sor
      Yorum Ekle
    2. Fujitsu Lifebook A6110 RAM Replacement: adım 2, 1 resimden 1.
      • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
      FixBot'a Sor
      Yorum Ekle
    1. Fujitsu Lifebook A6110 RAM Replacement, RAM: adım 3, 2 resimden 1. Fujitsu Lifebook A6110 RAM Replacement, RAM: adım 3, 2 resimden 2.
      • The RAM compartment will be located near the bottom-left corner of your lifebook. The compartment is behind the cover held in place by a 6 mm screw.
      • Using a Phillips #1 screwdriver, remove the 6 mm screw from the RAM compartment on the bottom-left corner of the rear cover.
      FixBot'a Sor
      Yorum Ekle
    2. Fujitsu Lifebook A6110 RAM Replacement: adım 4, 3 resimden 1. Fujitsu Lifebook A6110 RAM Replacement: adım 4, 3 resimden 2. Fujitsu Lifebook A6110 RAM Replacement: adım 4, 3 resimden 3.
      • Slide the cover towards the screw, and then lift the cover upwards.
      FixBot'a Sor
      Yorum Ekle
    3. Fujitsu Lifebook A6110 RAM Replacement: adım 5, 2 resimden 1. Fujitsu Lifebook A6110 RAM Replacement: adım 5, 2 resimden 2.
      • There are two RAM cards in this compartment. They look like small green plastic chips with black squares on each of them. These cards are beneath a thin plastic sheet that must be pulled out of the way.
      • Simultaneously pull each metal and plastic clip away from the center of the RAM stick.
      • If done correctly, the RAM card will eject at a 45 degree angle.
      FixBot'a Sor
      Yorum Ekle
    4. Fujitsu Lifebook A6110 RAM Replacement: adım 6, 1 resimden 1.
      • Pull the RAM card out while maintaining the 45 degree angle it ejected at.
      • When reassembling, the gold pins on the RAM card must match the corresponding pins found on the motherboard.
      • If you choose to replace the other RAM card, repeat the process in Step 5.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Cody Moniz
422 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 UMass Dartmouth, Team 3-2, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G2
3 Üyeler
50 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 1,360
