Ana içeriğe geç
Fujitsu Lifebook S6120 Keyboard Replacement
Neye ihtiyacın var
  1. Fujitsu Lifebook S6120 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Fujitsu Lifebook S6120 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Fujitsu Lifebook S6120 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: adım 2, 2 resimden 1. Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: adım 2, 2 resimden 2.
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
    FixBot'a Sor
    Yorum Ekle
  3. Fujitsu Lifebook S6120 Keyboard Replacement: adım 3, 1 resimden 1.
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
    FixBot'a Sor
    Yorum Ekle
  4. Fujitsu Lifebook S6120 Keyboard Replacement: adım 4, 3 resimden 1. Fujitsu Lifebook S6120 Keyboard Replacement: adım 4, 3 resimden 2. Fujitsu Lifebook S6120 Keyboard Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Fujitsu Lifebook S6120 Keyboard Replacement: adım 5, 3 resimden 1. Fujitsu Lifebook S6120 Keyboard Replacement: adım 5, 3 resimden 2. Fujitsu Lifebook S6120 Keyboard Replacement: adım 5, 3 resimden 3.
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
    FixBot'a Sor
    Yorum Ekle
  6. Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: adım 6, 3 resimden 1. Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: adım 6, 3 resimden 2. Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: adım 6, 3 resimden 3.
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
    FixBot'a Sor
    Yorum Ekle
  7. Fujitsu Lifebook S6120 Keyboard Replacement: adım 7, 3 resimden 1. Fujitsu Lifebook S6120 Keyboard Replacement: adım 7, 3 resimden 2. Fujitsu Lifebook S6120 Keyboard Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jessi Gallant
920 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G5, Peak Spring 2018 UMass Dartmouth, Team S5-G5, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S5G5
3 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 26
Her zaman: 1,656
