Ana içeriğe geç
Fujitsu Lifebook S6120 Motherboard Replacement
Neye ihtiyacın var
  1. Fujitsu Lifebook S6120 Motherboard Replacement, Battery: adım 1, 3 resimden 1. Fujitsu Lifebook S6120 Motherboard Replacement, Battery: adım 1, 3 resimden 2. Fujitsu Lifebook S6120 Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Motherboard Replacement, Hinge Cover: adım 2, 2 resimden 1. Fujitsu Lifebook S6120 Motherboard Replacement, Hinge Cover: adım 2, 2 resimden 2.
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Motherboard Replacement: adım 3, 1 resimden 1.
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Motherboard Replacement: adım 4, 3 resimden 1. Fujitsu Lifebook S6120 Motherboard Replacement: adım 4, 3 resimden 2. Fujitsu Lifebook S6120 Motherboard Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Motherboard Replacement: adım 5, 3 resimden 1. Fujitsu Lifebook S6120 Motherboard Replacement: adım 5, 3 resimden 2. Fujitsu Lifebook S6120 Motherboard Replacement: adım 5, 3 resimden 3.
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Motherboard Replacement, Keyboard: adım 6, 3 resimden 1. Fujitsu Lifebook S6120 Motherboard Replacement, Keyboard: adım 6, 3 resimden 2. Fujitsu Lifebook S6120 Motherboard Replacement, Keyboard: adım 6, 3 resimden 3.
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Motherboard Replacement: adım 7, 3 resimden 1. Fujitsu Lifebook S6120 Motherboard Replacement: adım 7, 3 resimden 2. Fujitsu Lifebook S6120 Motherboard Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
  8. Fujitsu Lifebook S6120 Motherboard Replacement, Motherboard: adım 8, 2 resimden 1. Fujitsu Lifebook S6120 Motherboard Replacement, Motherboard: adım 8, 2 resimden 2.
    • Use a Philips head #0 to remove the 5mm screws.
    • Use a Philips head #00 to remove the 4mm screws.
  9. Fujitsu Lifebook S6120 Motherboard Replacement: adım 9, 1 resimden 1.
    • Lift up the plastic frame from the base to expose the ribbon attached to the motherboard.
  10. Fujitsu Lifebook S6120 Motherboard Replacement: adım 10, 2 resimden 1. Fujitsu Lifebook S6120 Motherboard Replacement: adım 10, 2 resimden 2.
    Satın Al
    • Remove the ribbon from the motherboard with a pair of tweezers.
  11. Fujitsu Lifebook S6120 Motherboard Replacement: adım 11, 3 resimden 1. Fujitsu Lifebook S6120 Motherboard Replacement: adım 11, 3 resimden 2. Fujitsu Lifebook S6120 Motherboard Replacement: adım 11, 3 resimden 3.
    • Use a 5mm nut driver to unscrew the nuts.
  12. Fujitsu Lifebook S6120 Motherboard Replacement: adım 12, 2 resimden 1. Fujitsu Lifebook S6120 Motherboard Replacement: adım 12, 2 resimden 2.
    • Pull the ribbon tab up and off the motherboard.
  13. Fujitsu Lifebook S6120 Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the metal plate covering the motherboard.
  14. Fujitsu Lifebook S6120 Motherboard Replacement: adım 14, 2 resimden 1. Fujitsu Lifebook S6120 Motherboard Replacement: adım 14, 2 resimden 2.
    • Remove the 3.5mm screws with a Philips head #0.
    • Remove the metal bracket and other pieces that rely on it for structure.
  15. Fujitsu Lifebook S6120 Motherboard Replacement: adım 15, 2 resimden 1. Fujitsu Lifebook S6120 Motherboard Replacement: adım 15, 2 resimden 2.
    • Pinch your fingers around the base of the connector and pull it out.
  16. Fujitsu Lifebook S6120 Motherboard Replacement: adım 16, 2 resimden 1. Fujitsu Lifebook S6120 Motherboard Replacement: adım 16, 2 resimden 2.
    • Lift the motherboard off the plastic base.
Sonuç
Jessi Gallant
899 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G5, Peak Spring 2018 UMass Dartmouth, Team S5-G5, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S5G5
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 17
Her zaman: 1,048
