Ana içeriğe geç
Fujitsu Lifebook S6120 PCI Adapter Replacement
Neye ihtiyacın var
  1. Fujitsu Lifebook S6120 PCI Adapter Replacement, Battery: adım 1, 3 resimden 1. Fujitsu Lifebook S6120 PCI Adapter Replacement, Battery: adım 1, 3 resimden 2. Fujitsu Lifebook S6120 PCI Adapter Replacement, Battery: adım 1, 3 resimden 3.
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Fujitsu Lifebook S6120 PCI Adapter Replacement, Hinge Cover: adım 2, 2 resimden 1. Fujitsu Lifebook S6120 PCI Adapter Replacement, Hinge Cover: adım 2, 2 resimden 2.
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
    FixBot'a Sor
    Yorum Ekle
  3. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 3, 1 resimden 1.
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
    FixBot'a Sor
    Yorum Ekle
  4. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 4, 3 resimden 1. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 4, 3 resimden 2. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 5, 3 resimden 1. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 5, 3 resimden 2. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 5, 3 resimden 3.
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
    FixBot'a Sor
    Yorum Ekle
  6. Fujitsu Lifebook S6120 PCI Adapter Replacement, Keyboard: adım 6, 3 resimden 1. Fujitsu Lifebook S6120 PCI Adapter Replacement, Keyboard: adım 6, 3 resimden 2. Fujitsu Lifebook S6120 PCI Adapter Replacement, Keyboard: adım 6, 3 resimden 3.
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
    FixBot'a Sor
    Yorum Ekle
  7. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 7, 3 resimden 1. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 7, 3 resimden 2. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Fujitsu Lifebook S6120 PCI Adapter Replacement, PCI Adapter: adım 8, 3 resimden 1. Fujitsu Lifebook S6120 PCI Adapter Replacement, PCI Adapter: adım 8, 3 resimden 2. Fujitsu Lifebook S6120 PCI Adapter Replacement, PCI Adapter: adım 8, 3 resimden 3.
    • Push the secure clips outward.
    • The Adapter should pop up.
    FixBot'a Sor
    Yorum Ekle
  9. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 9, 3 resimden 1. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 9, 3 resimden 2. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 9, 3 resimden 3.
    • Use tweezers to remove the wires from the Adapter.
    FixBot'a Sor
    Yorum Ekle
  10. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 10, 2 resimden 1. Fujitsu Lifebook S6120 PCI Adapter Replacement: adım 10, 2 resimden 2.
    • Take out the Adapter and carefully pull the wires out from the metal casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jaimie Nakamura
235 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G5, Peak Spring 2018 UMass Dartmouth, Team S5-G5, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S5G5
3 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
Je suis vraiment intéressé merci.
Ravi de la leçon.
Jean Fella - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 1,279
