Ana içeriğe geç
Fujitsu Lifebook S6120 RAM Replacement
Neye ihtiyacın var
  1. Fujitsu Lifebook S6120 RAM Replacement, Battery: adım 1, 3 resimden 1. Fujitsu Lifebook S6120 RAM Replacement, Battery: adım 1, 3 resimden 2. Fujitsu Lifebook S6120 RAM Replacement, Battery: adım 1, 3 resimden 3.
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Fujitsu Lifebook S6120 RAM Replacement, RAM: adım 2, 2 resimden 1. Fujitsu Lifebook S6120 RAM Replacement, RAM: adım 2, 2 resimden 2.
    • Use a Philips head #0 to remove the 4mm screws to the RAM cover.
    FixBot'a Sor
    Yorum Ekle
  3. Fujitsu Lifebook S6120 RAM Replacement: adım 3, 3 resimden 1. Fujitsu Lifebook S6120 RAM Replacement: adım 3, 3 resimden 2. Fujitsu Lifebook S6120 RAM Replacement: adım 3, 3 resimden 3.
    • Use the plastic opening tool to lift the RAM cover.
    • Use your hands to slide the cover off.
    FixBot'a Sor
    Yorum Ekle
  4. Fujitsu Lifebook S6120 RAM Replacement: adım 4, 3 resimden 1. Fujitsu Lifebook S6120 RAM Replacement: adım 4, 3 resimden 2. Fujitsu Lifebook S6120 RAM Replacement: adım 4, 3 resimden 3.
    • Remove RAM module by pushing security clips outward.
    • The RAM module should pop out.
    • Carefully pull RAM module out of the computer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jessi Gallant
920 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G5, Peak Spring 2018 UMass Dartmouth, Team S5-G5, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S5G5
3 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 798
