Ana içeriğe geç
Fujitsu Lifebook S6120 Screen Replacement
Neye ihtiyacın var
  1. Fujitsu Lifebook S6120 Screen Replacement, Battery: adım 1, 3 resimden 1. Fujitsu Lifebook S6120 Screen Replacement, Battery: adım 1, 3 resimden 2. Fujitsu Lifebook S6120 Screen Replacement, Battery: adım 1, 3 resimden 3.
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Fujitsu Lifebook S6120 Screen Replacement, Hinge Cover: adım 2, 2 resimden 1. Fujitsu Lifebook S6120 Screen Replacement, Hinge Cover: adım 2, 2 resimden 2.
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
    FixBot'a Sor
    Yorum Ekle
  3. Fujitsu Lifebook S6120 Screen Replacement: adım 3, 1 resimden 1.
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
    FixBot'a Sor
    Yorum Ekle
  4. Fujitsu Lifebook S6120 Screen Replacement: adım 4, 3 resimden 1. Fujitsu Lifebook S6120 Screen Replacement: adım 4, 3 resimden 2. Fujitsu Lifebook S6120 Screen Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Fujitsu Lifebook S6120 Screen Replacement: adım 5, 3 resimden 1. Fujitsu Lifebook S6120 Screen Replacement: adım 5, 3 resimden 2. Fujitsu Lifebook S6120 Screen Replacement: adım 5, 3 resimden 3.
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
    FixBot'a Sor
    Yorum Ekle
  6. Fujitsu Lifebook S6120 Screen Replacement, Keyboard: adım 6, 3 resimden 1. Fujitsu Lifebook S6120 Screen Replacement, Keyboard: adım 6, 3 resimden 2. Fujitsu Lifebook S6120 Screen Replacement, Keyboard: adım 6, 3 resimden 3.
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
    FixBot'a Sor
    Yorum Ekle
  7. Fujitsu Lifebook S6120 Screen Replacement: adım 7, 3 resimden 1. Fujitsu Lifebook S6120 Screen Replacement: adım 7, 3 resimden 2. Fujitsu Lifebook S6120 Screen Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: adım 8, 3 resimden 1. Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: adım 8, 3 resimden 2. Fujitsu Lifebook S6120 Screen Replacement, PCI Adapter: adım 8, 3 resimden 3.
    • Push the secure clips outward.
    • The Adapter should pop up.
    FixBot'a Sor
    Yorum Ekle
  9. Fujitsu Lifebook S6120 Screen Replacement: adım 9, 3 resimden 1. Fujitsu Lifebook S6120 Screen Replacement: adım 9, 3 resimden 2. Fujitsu Lifebook S6120 Screen Replacement: adım 9, 3 resimden 3.
    • Use tweezers to remove the wires from the Adapter.
    FixBot'a Sor
    Yorum Ekle
  10. Fujitsu Lifebook S6120 Screen Replacement: adım 10, 2 resimden 1. Fujitsu Lifebook S6120 Screen Replacement: adım 10, 2 resimden 2.
    • Take out the Adapter and carefully pull the wires out from the metal casing.
    FixBot'a Sor
    Yorum Ekle
  11. Fujitsu Lifebook S6120 Screen Replacement, Screen: adım 11, 2 resimden 1. Fujitsu Lifebook S6120 Screen Replacement, Screen: adım 11, 2 resimden 2.
    • Remove the 4mm screws from the laptop with a Philips head #0
    • Remove the 4.5mm screws on the back of the laptop with a Philips #0
    FixBot'a Sor
    Yorum Ekle
  12. Fujitsu Lifebook S6120 Screen Replacement: adım 12, 3 resimden 1. Fujitsu Lifebook S6120 Screen Replacement: adım 12, 3 resimden 2. Fujitsu Lifebook S6120 Screen Replacement: adım 12, 3 resimden 3.
    • Use a plastic opening tool to lift up both sides of the white tab.
    FixBot'a Sor
    Yorum Ekle
  13. Fujitsu Lifebook S6120 Screen Replacement: adım 13, 2 resimden 1. Fujitsu Lifebook S6120 Screen Replacement: adım 13, 2 resimden 2.
    • Use tweezers to grab onto the lever to remove the chip from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  14. Fujitsu Lifebook S6120 Screen Replacement: adım 14, 1 resimden 1.
    • Lift the screen up vertically
    FixBot'a Sor
    Yorum Ekle
  15. Fujitsu Lifebook S6120 Screen Replacement: adım 15, 3 resimden 1. Fujitsu Lifebook S6120 Screen Replacement: adım 15, 3 resimden 2. Fujitsu Lifebook S6120 Screen Replacement: adım 15, 3 resimden 3.
    • Remove rubber tabs with hands
    • Use a Philips head #0 to remove the 3mm screws
    FixBot'a Sor
    Yorum Ekle
  16. Fujitsu Lifebook S6120 Screen Replacement: adım 16, 2 resimden 1. Fujitsu Lifebook S6120 Screen Replacement: adım 16, 2 resimden 2.
    • Use the metal spudger to pry up the edge of the plastic casing up.
    • Remove the plastic frame from the screen.
    FixBot'a Sor
    Yorum Ekle
  17. Fujitsu Lifebook S6120 Screen Replacement: adım 17, 1 resimden 1.
    • Remove the 3mm screws with a Philips head #00
    FixBot'a Sor
    Yorum Ekle
  18. Fujitsu Lifebook S6120 Screen Replacement: adım 18, 1 resimden 1.
    • Remove the 2.5mm screws with a Philips head #0 on both sides of the laptop
    FixBot'a Sor
    Yorum Ekle
  19. Fujitsu Lifebook S6120 Screen Replacement: adım 19, 2 resimden 1. Fujitsu Lifebook S6120 Screen Replacement: adım 19, 2 resimden 2.
    • Lift the screen from the frame
    FixBot'a Sor
    Yorum Ekle
  20. Fujitsu Lifebook S6120 Screen Replacement: adım 20, 2 resimden 1. Fujitsu Lifebook S6120 Screen Replacement: adım 20, 2 resimden 2.
    • Remove the ribbon from the back of the screen
    FixBot'a Sor
    Yorum Ekle
  21. Fujitsu Lifebook S6120 Screen Replacement: adım 21, 3 resimden 1. Fujitsu Lifebook S6120 Screen Replacement: adım 21, 3 resimden 2. Fujitsu Lifebook S6120 Screen Replacement: adım 21, 3 resimden 3.
    • Use a pair of tweezers remove the white connector
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jessi Gallant
920 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G5, Peak Spring 2018 UMass Dartmouth, Team S5-G5, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S5G5
3 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 1,501
