Giriş
If you need to replace your Battery for the Fujitsu Lifebook Stylistic Q584 this guide will provide step-by-step instructions. In addition, it's important to remove the battery prior to replacing parts.
Neye ihtiyacın var
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
2 farklı kişi bu kılavuzu tamamladı.
