Ana içeriğe geç
Fujitsu Lifebook Stylistic Q584 Buttons Replacement
Neye ihtiyacın var
  1. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement, Back Case: adım 1, 1 resimden 1.
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement: adım 2, 1 resimden 1.
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement: adım 3, 1 resimden 1.
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement, Buttons: adım 4, 1 resimden 1.
    • Locate the plastic buttons on left side of the device.
  5. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement: adım 5, 1 resimden 1.
    • Gently remove the plastic buttons.
Sonuç
Connor Stanton
613 İtibar
6 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 380
