Ana içeriğe geç
Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement
Neye ihtiyacın var
  1. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement, Back Case: adım 1, 1 resimden 1.
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: adım 2, 1 resimden 1.
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: adım 3, 1 resimden 1.
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement, Inner Back Shield: adım 4, 1 resimden 1.
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: adım 5, 1 resimden 1.
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: adım 6, 1 resimden 1.
  7. Fujitsu Lifebook Stylistic Q584 Inner Back Shield Replacement: adım 7, 1 resimden 1.
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
Sonuç
Spencer Bacon
410 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 478
