Ana içeriğe geç
Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement
Neye ihtiyacın var
  1. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Back Case: adım 1, 1 resimden 1.
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 2, 1 resimden 1.
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 3, 1 resimden 1.
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Inner Back Shield: adım 4, 1 resimden 1.
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 5, 1 resimden 1.
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 6, 1 resimden 1.
  7. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 7, 1 resimden 1.
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Battery: adım 8, 1 resimden 1.
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 9, 1 resimden 1.
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 10, 1 resimden 1.
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 11, 1 resimden 1.
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Motherboard: adım 12, 1 resimden 1.
    • Remove three 3mm screws using a PH00 screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 13, 1 resimden 1.
    • Remove all of the ribbon connector cables from the motherboard using an ESD-safe spudger.
  14. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 14, 1 resimden 1.
    • Gently pry up the motherboard.
  15. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 15, 1 resimden 1.
    • Gently lift the foil tape under the motherboard to reveal the connector.
  16. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 16, 3 resimden 1. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 16, 3 resimden 2. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 16, 3 resimden 3.
    • Remove the clip holding in the connector with an ESD-safe spudger.
  17. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: adım 17, 1 resimden 1.
    • Remove the connector with an ESD-safe spudger.
  18. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, MicroSD Card: adım 18, 1 resimden 1.
    • After removing the motherboard, use an ESD-safe spudger to pry up the MicroSD card from the slot.
    • Gently separate the MicroSD card from the device.
Sonuç
Casey
280 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Henning Spring 2019 IUPUI, Team S1-G1, Henning Spring 2019 üyesi
IUPUI-HENNING-S19S1G1
3 Üyeler
3 adet Kılavuz yazıldı
Bir Yorum
I have some OS problem can the SSD be replaced..?
Faiz Rahmathulla - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 474
