Ana içeriğe geç
Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement
Neye ihtiyacın var
  1. Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement, CMOS Battery: adım 1, 1 resimden 1.
    • Turn the laptop upside down and prepare the tools needed and the battery.
  2. Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement: adım 2, 1 resimden 1.
    • Remove the 4 philips screws that secure the back cover.
  3. Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement: adım 3, 1 resimden 1.
    • With the cover removed, we can see the battery.
  4. Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement: adım 4, 1 resimden 1.
    • Turn the laptop around so you can see and access the battery. Release the battery with the flat screwdriver (1), then gently push it upward (2). Be careful not to let it slip into the laptop case or you will have to disassemble it completely.
  5. Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement: adım 5, 2 resimden 1. Fujitsu Siemens Esprimo Mobile v5515 CMOS Battery Replacement: adım 5, 2 resimden 2.
    • If you have a multimeter, check the old battery. A good one should read 3 V or higher. A fresh one reads 3.2 V or more.
    • In this case, the old was really bad, at only 2.7 V.
    • The replacement one is good, 3.22 V.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Nicola Nascimento
372 İtibar
1 Kılavuz yazıldı
Bir Yorum
nice... do you have information about the location of the cmos battery in the Fujitsu LH 532 model? rosez.v@hotmail.com
Victor Rosez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 13,663
