Ana içeriğe geç
Function Key Motherboard
Neye ihtiyacın var
  1. Function Key Motherboard, Front and Back Covers: adım 1, 3 resimden 1. Function Key Motherboard, Front and Back Covers: adım 1, 3 resimden 2. Function Key Motherboard, Front and Back Covers: adım 1, 3 resimden 3.
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
    FixBot'a Sor
    Yorum Ekle
  2. Function Key Motherboard: adım 2, 1 resimden 1.
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
    FixBot'a Sor
    Yorum Ekle
  3. Function Key Motherboard: adım 3, 1 resimden 1.
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Function Key Motherboard: adım 4, 2 resimden 1. Function Key Motherboard: adım 4, 2 resimden 2.
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  5. Function Key Motherboard: adım 5, 1 resimden 1.
    • The camera should look like this once the front cover is removed.
    FixBot'a Sor
    Yorum Ekle
  6. Function Key Motherboard: adım 6, 3 resimden 1. Function Key Motherboard: adım 6, 3 resimden 2. Function Key Motherboard: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
    FixBot'a Sor
    Yorum Ekle
  7. Function Key Motherboard: adım 7, 1 resimden 1.
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
    FixBot'a Sor
    Yorum Ekle
  8. Function Key Motherboard, Function Key Motherboard: adım 8, 3 resimden 1. Function Key Motherboard, Function Key Motherboard: adım 8, 3 resimden 2. Function Key Motherboard, Function Key Motherboard: adım 8, 3 resimden 3.
    • Remove 2 4.35mm phillips head screws from around the LCD screen using a #00 phillips head screwdriver.
    • Caution: Do not tug on the LCD screen because this could tear the ribbon connecting the LCD screen to the body of the camera.
    • Loosen the black ribbon clamp using an iPod opening tool
    • Release the LCD screen by removing the ribbon from the body of the camera.
    FixBot'a Sor
    Yorum Ekle
  9. Function Key Motherboard: adım 9, 2 resimden 1. Function Key Motherboard: adım 9, 2 resimden 2.
    • Unscrew 2 3.35mm phillips head screw from the face of the function key motherboard using a #00 phillips head screwdriver.
    • Caution: Do not tug on the motherboard because this will tear the ribbon connecting the motherboard to the body of the camera.
    FixBot'a Sor
    Yorum Ekle
  10. Function Key Motherboard: adım 10, 3 resimden 1. Function Key Motherboard: adım 10, 3 resimden 2. Function Key Motherboard: adım 10, 3 resimden 3.
    • Release the black ribbon clamp attached to the back of the motherboard using an iPod opening tool to lift the clamp.
    • Remove the ribbon connecting the function key motherboard from the body of the camera using tweezers.
    • The function key motherboard has the SD card reader attached to the back. The motherboard and SD card combination should be replaced.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shaelyn Thomas
392 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-6, Regan Spring 2011 Cal Poly, Team 8-6, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G6
4 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 36
Her zaman: 3,762
