Ana içeriğe geç
Furbo Dog Camera Back Cover Replacement
Neye ihtiyacın var
  1. Furbo Dog Camera Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Furbo Dog Camera Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the lid from the top of your Furbo Dog Camera.
  2. Furbo Dog Camera Back Cover Replacement: adım 2, 3 resimden 1. Furbo Dog Camera Back Cover Replacement: adım 2, 3 resimden 2. Furbo Dog Camera Back Cover Replacement: adım 2, 3 resimden 3.
    • Rotate your Furbo so that the bottom faces you.
    • Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
  3. Furbo Dog Camera Back Cover Replacement: adım 3, 3 resimden 1. Furbo Dog Camera Back Cover Replacement: adım 3, 3 resimden 2. Furbo Dog Camera Back Cover Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Satın Al
    • Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
    • Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
  4. Furbo Dog Camera Back Cover Replacement: adım 4, 3 resimden 1. Furbo Dog Camera Back Cover Replacement: adım 4, 3 resimden 2. Furbo Dog Camera Back Cover Replacement: adım 4, 3 resimden 3.
    • Rotate your Furbo so that the side is facing towards you.
    • Use an opening tool to separate the two plastic coverings.
  5. Furbo Dog Camera Back Cover Replacement: adım 5, 2 resimden 1. Furbo Dog Camera Back Cover Replacement: adım 5, 2 resimden 2.
    • Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
Sonuç
Sarah Teague
265 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 1,230
