Ana içeriğe geç
Furbo Dog Camera USB Power Jack Replacement
Neye ihtiyacın var
  1. Furbo Dog Camera USB Power Jack Replacement, Back Cover: adım 1, 2 resimden 1. Furbo Dog Camera USB Power Jack Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the lid from the top of your Furbo Dog Camera.
  2. Furbo Dog Camera USB Power Jack Replacement: adım 2, 3 resimden 1. Furbo Dog Camera USB Power Jack Replacement: adım 2, 3 resimden 2. Furbo Dog Camera USB Power Jack Replacement: adım 2, 3 resimden 3.
    • Rotate your Furbo so that the bottom faces you.
    • Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
  3. Furbo Dog Camera USB Power Jack Replacement: adım 3, 3 resimden 1. Furbo Dog Camera USB Power Jack Replacement: adım 3, 3 resimden 2. Furbo Dog Camera USB Power Jack Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Satın Al
    • Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
    • Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
  4. Furbo Dog Camera USB Power Jack Replacement: adım 4, 3 resimden 1. Furbo Dog Camera USB Power Jack Replacement: adım 4, 3 resimden 2. Furbo Dog Camera USB Power Jack Replacement: adım 4, 3 resimden 3.
    • Rotate your Furbo so that the side is facing towards you.
    • Use an opening tool to separate the two plastic coverings.
  5. Furbo Dog Camera USB Power Jack Replacement: adım 5, 2 resimden 1. Furbo Dog Camera USB Power Jack Replacement: adım 5, 2 resimden 2.
    • Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
  6. Furbo Dog Camera USB Power Jack Replacement, USB Power Jack: adım 6, 2 resimden 1. Furbo Dog Camera USB Power Jack Replacement, USB Power Jack: adım 6, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the two 5 mm screws from the USB power jack.
  7. Furbo Dog Camera USB Power Jack Replacement: adım 7, 2 resimden 1. Furbo Dog Camera USB Power Jack Replacement: adım 7, 2 resimden 2.
    • Once you have removed the screws, gently pull the bundled cable connector free from the motherboard.
  8. Furbo Dog Camera USB Power Jack Replacement: adım 8, 3 resimden 1. Furbo Dog Camera USB Power Jack Replacement: adım 8, 3 resimden 2. Furbo Dog Camera USB Power Jack Replacement: adım 8, 3 resimden 3.
    • The USB power jack PCB can now be removed from your Furbo and replaced.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Piper Strgar
309 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Where can you find a replacement
Brandon Alves - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 39
Her zaman: 1,222
