Ana içeriğe geç
Furnace Humidifier Evaporator Pad Replacement
Neye ihtiyacın var
  1. Furnace Humidifier Evaporator Pad Replacement, Furnace Humidifier Evaporator Pad: adım 1, 1 resimden 1.
    • Turn off the humidifier. (Set the humidistat to 0% humidity)
  2. Furnace Humidifier Evaporator Pad Replacement: adım 2, 2 resimden 1. Furnace Humidifier Evaporator Pad Replacement: adım 2, 2 resimden 2.
    • Remove the nuts and clips holding the top cover of the cabinet assembly to the bottom cabinet housing.
  3. Furnace Humidifier Evaporator Pad Replacement: adım 3, 1 resimden 1.
    • Remove the side clips or fasteners.
  4. Furnace Humidifier Evaporator Pad Replacement: adım 4, 1 resimden 1.
    • Use an adjustable wrench to loosen the nut which holds the water distributor tube and swing the tube out of its secured place.
  5. Furnace Humidifier Evaporator Pad Replacement: adım 5, 1 resimden 1.
    • Remove the top of the bottom cabinet housing and take out the evaporator pad.
  6. Furnace Humidifier Evaporator Pad Replacement: adım 6, 2 resimden 1. Furnace Humidifier Evaporator Pad Replacement: adım 6, 2 resimden 2.
    • Place the new evaporator pad inside the clean bottom cabinet.
    • The sides should guide it into the correct position.
  7. Furnace Humidifier Evaporator Pad Replacement: adım 7, 1 resimden 1.
    • Replace the clips, nuts, and bolts removed in steps 2 through 4.
  8. Furnace Humidifier Evaporator Pad Replacement: adım 8, 1 resimden 1.
    • Turn on the humidifier.
Sonuç
Enjoy your warm air! Your repair is complete!
Zia Ahmed
190 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 386
