Ana içeriğe geç
Furnace Humidifier Evaporator Pad Replacement
Görüntüleme: 1,2 B
İstatistikleri görüntüle:
Son 24 Saat:
3
Son 7 Gün:
31
Son 30 Gün:
89
Her zaman:
1.192
Yorumlar: 0
Hiç kimse bu kılavuza yorum bırakmadı. Birinci olacak mısın?
Go to guide comments
Tamamlandı: 0
Hiç kimse bu kılavuzu "tamamlandı" olarak işaretlemedi. İlk mi olacaksın?
Sık Kullanılanlar: 0
Hiç kimse bu kılavuzu favorilere eklemedi (ve abone olmadı). İlk mi olacaksın?
Gerekli Süre: 30 dakika
Zorluk: Orta
Furnace humidifiers are built in almost every household and their function is to help add moisture to the air to keep homes warm especially during the winter. If your furnace humidifier is not working optimally and producing enough warmth, this guide is helpful as there are times when you won’t be able to use an old evaporator pad optimally. Eventually, all the dust and particles can cause mold to grow on the evaporator pad. So, to find a solution to this, one would need to buy a new evaporator pad and replace the old one.
Neye ihtiyacın var
    1. Furnace Humidifier Evaporator Pad Replacement, Furnace Humidifier Evaporator Pad: adım 1, 1 resimden 1.
      • Turn off the humidifier. (Set the humidistat to 0% humidity)
      FixBot'a Sor
      Yorum Ekle
    2. Furnace Humidifier Evaporator Pad Replacement: adım 2, 2 resimden 1. Furnace Humidifier Evaporator Pad Replacement: adım 2, 2 resimden 2.
      • Remove the nuts and clips holding the top cover of the cabinet assembly to the bottom cabinet housing.
      FixBot'a Sor
      Yorum Ekle
    3. Furnace Humidifier Evaporator Pad Replacement: adım 3, 1 resimden 1.
      • Remove the side clips or fasteners.
      FixBot'a Sor
      Yorum Ekle
    4. Furnace Humidifier Evaporator Pad Replacement: adım 4, 1 resimden 1.
      • Use an adjustable wrench to loosen the nut which holds the water distributor tube and swing the tube out of its secured place.
      FixBot'a Sor
      Yorum Ekle
    5. Furnace Humidifier Evaporator Pad Replacement: adım 5, 1 resimden 1.
      • Remove the top of the bottom cabinet housing and take out the evaporator pad.
      FixBot'a Sor
      Yorum Ekle
    6. Furnace Humidifier Evaporator Pad Replacement: adım 6, 2 resimden 1. Furnace Humidifier Evaporator Pad Replacement: adım 6, 2 resimden 2.
      • Place the new evaporator pad inside the clean bottom cabinet.
      • The sides should guide it into the correct position.
      FixBot'a Sor
      Yorum Ekle
    7. Furnace Humidifier Evaporator Pad Replacement: adım 7, 1 resimden 1.
      • Replace the clips, nuts, and bolts removed in steps 2 through 4.
      FixBot'a Sor
      Yorum Ekle
    8. Furnace Humidifier Evaporator Pad Replacement: adım 8, 1 resimden 1.
      • Turn on the humidifier.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Enjoy your warm air! Your repair is complete!
Yazar
ile
Zia Ahmed
190 İtibar
1 Kılavuz yazıldı
Ekip
York University, Team F-30, Woodhouse Fall 2021 York University, Team F-30, Woodhouse Fall 2021 üyesi
YORK-WOODHOUSE-F21SFG30
1 Üye
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 31
Son 30 gün: 89
Her zaman: 1,192
