Ana içeriğe geç
G&G CM RK47 Airsoft Disassembly
Neye ihtiyacın var
  1. G&G CM RK47 Airsoft Disassembly, G&G Combat Machine RK47: adım 1, 3 resimden 1. G&G CM RK47 Airsoft Disassembly, G&G Combat Machine RK47: adım 1, 3 resimden 2. G&G CM RK47 Airsoft Disassembly, G&G Combat Machine RK47: adım 1, 3 resimden 3.
    • Start by pressing the top cover retainer button and lifting the top cover off of the gun.
  2. G&G CM RK47 Airsoft Disassembly: adım 2, 3 resimden 1. G&G CM RK47 Airsoft Disassembly: adım 2, 3 resimden 2. G&G CM RK47 Airsoft Disassembly: adım 2, 3 resimden 3.
    • Pull the thin black rod away from the top cover button and swing it outwards.
    • Remove the small screw from the plastic receiver cover using a #0 Phillips screwdriver.
  3. G&G CM RK47 Airsoft Disassembly: adım 3, 2 resimden 1. G&G CM RK47 Airsoft Disassembly: adım 3, 2 resimden 2.
    • Lift the plastic receiver cover from the receiver and remove it.
    • Slide the top cover retainer button out of its groove and remove it.
  4. G&G CM RK47 Airsoft Disassembly: adım 4, 3 resimden 1. G&G CM RK47 Airsoft Disassembly: adım 4, 3 resimden 2. G&G CM RK47 Airsoft Disassembly: adım 4, 3 resimden 3.
    • Remove the four screws on the underside of the receiver with a 2mm hex driver.
    • Pull the barrel assembly out of the receiver.
    • Remove the two screws holding the hop-up unit in place.
    • Pull the inner barrel out of the outer barrel.
  5. G&G CM RK47 Airsoft Disassembly: adım 5, 2 resimden 1. G&G CM RK47 Airsoft Disassembly: adım 5, 2 resimden 2.
    • Remove the screw a the bottom of the pistol grip with a #2 Phillips screwdriver.
    • Remove the two motor mount screws with a 2mm hex driver.
  6. G&G CM RK47 Airsoft Disassembly: adım 6, 3 resimden 1. G&G CM RK47 Airsoft Disassembly: adım 6, 3 resimden 2. G&G CM RK47 Airsoft Disassembly: adım 6, 3 resimden 3.
    • Using a flat head screwdriver, pry off the selector lever cap.
    • Once the cap is removed, remove the screw underneath with a #2 Phillips screwdriver.
    • Remove the selector lever.
  7. G&G CM RK47 Airsoft Disassembly: adım 7, 3 resimden 1. G&G CM RK47 Airsoft Disassembly: adım 7, 3 resimden 2. G&G CM RK47 Airsoft Disassembly: adım 7, 3 resimden 3.
    • Carefully remove the gearbox from the receiver, making sure that the wires don't get stuck.
  8. G&G CM RK47 Airsoft Disassembly: adım 8, 3 resimden 1. G&G CM RK47 Airsoft Disassembly: adım 8, 3 resimden 2. G&G CM RK47 Airsoft Disassembly: adım 8, 3 resimden 3.
    • Using a 2.5mm hex driver, remove the three screws that hold the stock to the receiver.
    • Pull the stock away from the receiver to remove it.
  9. G&G CM RK47 Airsoft Disassembly: adım 9, 3 resimden 1. G&G CM RK47 Airsoft Disassembly: adım 9, 3 resimden 2. G&G CM RK47 Airsoft Disassembly: adım 9, 3 resimden 3.
    • Remove the safety from the right side of the gearbox.
    • Remove the selector gear screw with a 2mm hex driver as shown.
    • Remove the selector gear assembly.
  10. G&G CM RK47 Airsoft Disassembly: adım 10, 3 resimden 1. G&G CM RK47 Airsoft Disassembly: adım 10, 3 resimden 2. G&G CM RK47 Airsoft Disassembly: adım 10, 3 resimden 3.
    • Lift the tabs on the small black cap behind the trigger, and then remove the cap.
    • Pull the wires out from under the tabs on the spring plate that runs along the top of the gearbox.
    • Carefully remove the spring plate by tapping it gently with a plastic hammer until it slides off the front of the gearbox.
  11. G&G CM RK47 Airsoft Disassembly: adım 11, 3 resimden 1. G&G CM RK47 Airsoft Disassembly: adım 11, 3 resimden 2. G&G CM RK47 Airsoft Disassembly: adım 11, 3 resimden 3.
    • Remove the four remaining gearbox screws with a 2mm hex driver.
    • Hold down the cylinder with your thumb while prying the gearbox apart from the top.
    • As you remove the right half of the gearbox, be sure to hold down the cylinder, piston, and spring assembly so that they do not pop out under tension.
    • Also keep a close eye out for any gear shims that may dislodge themselves as you are taking the gearbox apart.
  12. G&G CM RK47 Airsoft Disassembly: adım 12, 3 resimden 1. G&G CM RK47 Airsoft Disassembly: adım 12, 3 resimden 2. G&G CM RK47 Airsoft Disassembly: adım 12, 3 resimden 3.
    • Slowly lift the spring guide out of the gearbox along with the piston spring.
    • Remove the entire piston and cylinder assembly with the tappet plate, tappet plate spring, and air nozzle.
    • Remove the trigger assembly and lift up the wire harness, unhooking the trigger plunger spring in the process.
  13. G&G CM RK47 Airsoft Disassembly: adım 13, 3 resimden 1. G&G CM RK47 Airsoft Disassembly: adım 13, 3 resimden 2. G&G CM RK47 Airsoft Disassembly: adım 13, 3 resimden 3.
    • Pull the trigger plunger out of the wire harness.
    • Remove the three gears and the anti-reversal latch. Be careful not to misplace any of the shims or bushings, or the anti-reversal latch spring.
  14. G&G CM RK47 Airsoft Disassembly: adım 14, 1 resimden 1.
    • The RK47 is now fully disassembled.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
101 Tech USA
4.127 İtibar
17 adet Kılavuz yazıldı
Bir Yorum
That is really cool, and where can you buy this!
Ultimate Gamer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 7,107
