1. There are 4 black screws that need to be removed on the top of the lid.  A 1.5mm flathead screwdriver will work on the star shaped screw heads.
    • There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
    • Make note that two of the screws closest to the hinge are longer than the other two.
  2. Remove the two side screws. When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
    • Remove the two side screws.
    • When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
  3. Use a plastic opening tool to remove the screen cover from the rest of the lid. Use a plastic opening tool to remove the screen cover from the rest of the lid.
    • Use a plastic opening tool to remove the screen cover from the rest of the lid.
  4. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Your phone should look like the picture to the left. If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
    • Your phone should look like the picture to the left.
    • If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
  6. Remove one screw located on the left side of the phone with the pictured orientation in mind. This will release the logic board from the back case. Lift the board out of the case starting with the top. Continue to fold it forwards to access the ribbon cable still connecting it.
    • Remove one screw located on the left side of the phone with the pictured orientation in mind.
    • This will release the logic board from the back case.
    • Lift the board out of the case starting with the top. Continue to fold it forwards to access the ribbon cable still connecting it.
  7. Pull the logic board out with a pry stick gently from bottom to top at the current orientation. The ribbon cable will be connected underneath the logic board.  A small amount of force is required to disconnect them. Although some force is required to lift up the board, be careful as to not bend any of the pins on either side.
    • Pull the logic board out with a pry stick gently from bottom to top at the current orientation.
    • The ribbon cable will be connected underneath the logic board. A small amount of force is required to disconnect them.
    • Although some force is required to lift up the board, be careful as to not bend any of the pins on either side.
  8. Lift speaker towards yourself out of the white plastic container. Gently unplug the ribbon by pulling it to the left with the pictured orientation in mind.
    • Lift speaker towards yourself out of the white plastic container.
    • Gently unplug the ribbon by pulling it to the left with the pictured orientation in mind.
    • Be careful when unplugging connector as the ribbon connecting piece is extremely fragile.'
Sonuç
Raymond Caulder
22 İtibar
3 adet Kılavuz yazıldı
Takım
Clemson, Team 13-3, Benson Spring 2013 Clemson, Team 13-3, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G3
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 1
Son 30 Gün: 1
Her zaman: 257
