Ana içeriğe geç
G-Wolves Hati Paracord Replacement
Neye ihtiyacın var
  1. G-Wolves Hati Paracord Replacement, Mouse Paracord: adım 1, 1 resimden 1.
    • Flip your mouse upside down.
  2. G-Wolves Hati Paracord Replacement: adım 2, 3 resimden 1. G-Wolves Hati Paracord Replacement: adım 2, 3 resimden 2. G-Wolves Hati Paracord Replacement: adım 2, 3 resimden 3.
    • Peel off the back right mouse skate.
    • Peel slowly, you don't want to create bends on your skate.
  3. G-Wolves Hati Paracord Replacement: adım 3, 3 resimden 1. G-Wolves Hati Paracord Replacement: adım 3, 3 resimden 2. G-Wolves Hati Paracord Replacement: adım 3, 3 resimden 3.
    • Peel off the back left mouse skate.
  4. G-Wolves Hati Paracord Replacement: adım 4, 3 resimden 1. G-Wolves Hati Paracord Replacement: adım 4, 3 resimden 2. G-Wolves Hati Paracord Replacement: adım 4, 3 resimden 3.
    • Unscrew both of the uncovered screws.
    • 6.4mm Phillips-head screws.
  5. G-Wolves Hati Paracord Replacement: adım 5, 2 resimden 1. G-Wolves Hati Paracord Replacement: adım 5, 2 resimden 2.
    • Squeeze the mouse under second mouse button until the bottom opens.
  6. G-Wolves Hati Paracord Replacement: adım 6, 2 resimden 1. G-Wolves Hati Paracord Replacement: adım 6, 2 resimden 2.
    • Pull the bottom piece towards the back of the mouse and upwards to remove it.
    • Pull carefully there is a ribbon cable still connected.
  7. G-Wolves Hati Paracord Replacement: adım 7, 2 resimden 1. G-Wolves Hati Paracord Replacement: adım 7, 2 resimden 2.
    • Remove the ribbon cable connecting the bottom piece to the upper piece.
  8. G-Wolves Hati Paracord Replacement: adım 8, 2 resimden 1. G-Wolves Hati Paracord Replacement: adım 8, 2 resimden 2.
    • Unscrew the following screws:
    • 4.8 mm Phillips-head screws.
  9. G-Wolves Hati Paracord Replacement: adım 9, 2 resimden 1. G-Wolves Hati Paracord Replacement: adım 9, 2 resimden 2.
    • Flip the bottom piece upside down.
    • Pull the circuit board off without pulling on the cable.
  10. G-Wolves Hati Paracord Replacement: adım 10, 3 resimden 1. G-Wolves Hati Paracord Replacement: adım 10, 3 resimden 2. G-Wolves Hati Paracord Replacement: adım 10, 3 resimden 3.
    • Grab the side ridges and remove the connection.
    • Do not wiggle till slightly removed to not bend pins.
  11. G-Wolves Hati Paracord Replacement: adım 11, 2 resimden 1. G-Wolves Hati Paracord Replacement: adım 11, 2 resimden 2.
    • Pop off the paracord from the bottom piece.
  12. G-Wolves Hati Paracord Replacement: adım 12, 2 resimden 1. G-Wolves Hati Paracord Replacement: adım 12, 2 resimden 2.
    • Press in the new paracord.
  13. G-Wolves Hati Paracord Replacement: adım 13, 3 resimden 1. G-Wolves Hati Paracord Replacement: adım 13, 3 resimden 2. G-Wolves Hati Paracord Replacement: adım 13, 3 resimden 3.
    • Rearrange wires to follow the guide ridges.
  14. G-Wolves Hati Paracord Replacement: adım 14, 2 resimden 1. G-Wolves Hati Paracord Replacement: adım 14, 2 resimden 2.
    • Re-insert the circuit board by lining up the scroll wheel with the front piece and pressing down.
  15. G-Wolves Hati Paracord Replacement: adım 15, 2 resimden 1. G-Wolves Hati Paracord Replacement: adım 15, 2 resimden 2.
    • Re-insert the screws.
  16. G-Wolves Hati Paracord Replacement: adım 16, 2 resimden 1. G-Wolves Hati Paracord Replacement: adım 16, 2 resimden 2.
    • Thread the wire through the side opening.
    • Insert the paracord connection.
  17. G-Wolves Hati Paracord Replacement: adım 17, 2 resimden 1. G-Wolves Hati Paracord Replacement: adım 17, 2 resimden 2.
    • Insert the ribbon cable.
    • Cable is located on the upper mouse piece.
  18. G-Wolves Hati Paracord Replacement: adım 18, 3 resimden 1. G-Wolves Hati Paracord Replacement: adım 18, 3 resimden 2. G-Wolves Hati Paracord Replacement: adım 18, 3 resimden 3.
    • Hover the bottom piece over the upper piece flipped over.
    • Press the bottom piece down and forward till under clip pieces.
    • Press down where skates where removed till there is a click.
  19. G-Wolves Hati Paracord Replacement: adım 19, 2 resimden 1. G-Wolves Hati Paracord Replacement: adım 19, 2 resimden 2.
    • Insert the screws.
    • 6.4mm Phillips Head Screws.
  20. G-Wolves Hati Paracord Replacement: adım 20, 3 resimden 1. G-Wolves Hati Paracord Replacement: adım 20, 3 resimden 2. G-Wolves Hati Paracord Replacement: adım 20, 3 resimden 3.
    • Press on the skates.
Bitiş Çizgisi
Ayaan
301 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 41
Her zaman: 541
