Ana içeriğe geç
GATEWAY ML6720 Battery Replacement
Neye ihtiyacın var
    • Flip the laptop on to the backside.
  1. GATEWAY ML6720 Battery Replacement: adım 2, 1 resimden 1.
    • Locate the battery at the very top on the backside of the laptop.
  2. GATEWAY ML6720 Battery Replacement: adım 3, 2 resimden 1. GATEWAY ML6720 Battery Replacement: adım 3, 2 resimden 2.
    • Slide the latch in the top right corner to the right, to set it to unlocked.
  3. GATEWAY ML6720 Battery Replacement: adım 4, 2 resimden 1. GATEWAY ML6720 Battery Replacement: adım 4, 2 resimden 2.
    • Hold the other latch in the top left corner to the left.
    • Hold it in that place with your thumb until the completion of the next step. (This step unlocks the second latch.)
  4. GATEWAY ML6720 Battery Replacement: adım 5, 2 resimden 1. GATEWAY ML6720 Battery Replacement: adım 5, 2 resimden 2.
    • With both latches unlocked you can now slide out the battery, by pushing it off the top.
Sonuç
Nathan Da Silva
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 UMass Dartmouth, Team 2-3, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G3
2 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 337
