Ana içeriğe geç
GATEWAY ML6720 Disc Drive Replacement
Neye ihtiyacın var
  1. GATEWAY ML6720 Disc Drive Replacement, Disc Drive: adım 1, 1 resimden 1.
    • Remove the six screws with the Phillips #0 Screwdriver that secures the middle large piece of the back panel.
  2. GATEWAY ML6720 Disc Drive Replacement: adım 2, 2 resimden 1. GATEWAY ML6720 Disc Drive Replacement: adım 2, 2 resimden 2.
    • Check to see if your laptop requires a screw(s) to be removed for the disc drive. Remove the screw (s) holding the disc drive down.
  3. GATEWAY ML6720 Disc Drive Replacement: adım 3, 2 resimden 1. GATEWAY ML6720 Disc Drive Replacement: adım 3, 2 resimden 2.
    • With that screw removed, you can now pull the disc drive out of the laptop by pulling on it in the direction that it slides.
Sonuç
Semirah Dolan
113 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 UMass Dartmouth, Team 2-3, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G3
2 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 227
