Ana içeriğe geç
GATEWAY ML6720 Hard Drive Replacement
Neye ihtiyacın var
  1. GATEWAY ML6720 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Flip the laptop on to its backside.
  2. GATEWAY ML6720 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Locate the hard drive at the bottom left corner of the laptop's backside.
  3. GATEWAY ML6720 Hard Drive Replacement: adım 3, 2 resimden 1. GATEWAY ML6720 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Insert the correct screwdriver mentioned in this guide.
    • Fully loosen and remove each of the two screws located at the top left and bottom left corners of the hard drive's cover plate.
  4. GATEWAY ML6720 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Slide the hard drive's cover plate out to the left and take it off.
  5. GATEWAY ML6720 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Pop the hard drive out of the compartment.
Sonuç
Nathan Da Silva
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 UMass Dartmouth, Team 2-3, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G3
2 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 394
