Ana içeriğe geç
GATEWAY ML6720 Keyboard Replacement
Neye ihtiyacın var
    • Flip the laptop on to the backside.
  1. GATEWAY ML6720 Keyboard Replacement: adım 2, 1 resimden 1.
    • Locate the battery at the very top on the backside of the laptop.
  2. GATEWAY ML6720 Keyboard Replacement: adım 3, 2 resimden 1. GATEWAY ML6720 Keyboard Replacement: adım 3, 2 resimden 2.
    • Slide the latch in the top right corner to the right, to set it to unlocked.
  3. GATEWAY ML6720 Keyboard Replacement: adım 4, 2 resimden 1. GATEWAY ML6720 Keyboard Replacement: adım 4, 2 resimden 2.
    • Hold the other latch in the top left corner to the left.
    • Hold it in that place with your thumb until the completion of the next step. (This step unlocks the second latch.)
  4. GATEWAY ML6720 Keyboard Replacement: adım 5, 2 resimden 1. GATEWAY ML6720 Keyboard Replacement: adım 5, 2 resimden 2.
    • With both latches unlocked you can now slide out the battery, by pushing it off the top.
  5. GATEWAY ML6720 Keyboard Replacement, Keyboard: adım 6, 1 resimden 1.
    • Turn the laptop on its backside with the stickers and barcode facing you.
  6. GATEWAY ML6720 Keyboard Replacement: adım 7, 3 resimden 1. GATEWAY ML6720 Keyboard Replacement: adım 7, 3 resimden 2. GATEWAY ML6720 Keyboard Replacement: adım 7, 3 resimden 3.
    • Be careful of losing the screws because of how small they are
    • Remove the six 2.0mm Phillips screws and panels from the back of the RAM, motherboard, and laptop fan.
  7. GATEWAY ML6720 Keyboard Replacement: adım 8, 1 resimden 1.
    • Have your laptop remained on the backside
    • Remove the twelve identical 2.0mm Phillips Screws located around the back of the laptop using the Phillips #0 Screwdriver.
    • Remove the entire back panel of the laptop
  8. GATEWAY ML6720 Keyboard Replacement: adım 9, 2 resimden 1. GATEWAY ML6720 Keyboard Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers or the tip of your screw driver, dig into the laptop cover and apply force to pop it out.
    • Do this on the left and right side of the cover.
  9. GATEWAY ML6720 Keyboard Replacement: adım 10, 2 resimden 1. GATEWAY ML6720 Keyboard Replacement: adım 10, 2 resimden 2.
    • Pull up the keyboard with your finger.
Sonuç
Nathan Da Silva
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 UMass Dartmouth, Team 2-3, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G3
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 575
