Ana içeriğe geç
GATEWAY ML6720 Wireless Card Replacement
Neye ihtiyacın var
  1. GATEWAY ML6720 Wireless Card Replacement, Wireless Card: adım 1, 1 resimden 1.
    • Flip the laptop upside-down.
  2. GATEWAY ML6720 Wireless Card Replacement: adım 2, 2 resimden 1. GATEWAY ML6720 Wireless Card Replacement: adım 2, 2 resimden 2.
    • Locate the wireless card cover, found on the middle-left section of the laptop as shown.
  3. GATEWAY ML6720 Wireless Card Replacement: adım 3, 2 resimden 1. GATEWAY ML6720 Wireless Card Replacement: adım 3, 2 resimden 2.
    • Using the 1.5 mm Flathead Screwdriver, remove the cover screw at the top of the wireless card's cover plate.
  4. GATEWAY ML6720 Wireless Card Replacement: adım 4, 1 resimden 1.
    • Pull the wireless card's cover plate up and off to reveal the card as shown.
  5. GATEWAY ML6720 Wireless Card Replacement: adım 5, 1 resimden 1.
    • Remove the two wires connected to the wireless card.
  6. GATEWAY ML6720 Wireless Card Replacement: adım 6, 2 resimden 1. GATEWAY ML6720 Wireless Card Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Flathead 1.5 mm Screwdriver
    $5.49
    • Using the 1.5 mm Flathead Screwdriver, remove the two screws at the top left and right corners of the wireless card.
    • Slide the wireless card up and out of the compartment.
Sonuç
Nathan Da Silva
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 UMass Dartmouth, Team 2-3, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G3
2 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 308
