Ana içeriğe geç
GATEWAY NE56R09u Wireless Card Replacement
Neye ihtiyacın var
  1. GATEWAY NE56R09u  Wireless Card Replacement, Battery: adım 1, 1 resimden 1.
    • Before you begin, make sure the laptop is turned off.
    • Flip your laptop over so the bottom is facing up.
    FixBot'a Sor
    Yorum Ekle
  2. GATEWAY NE56R09u  Wireless Card Replacement: adım 2, 1 resimden 1.
    • Using a nylon spudger or your fingers, push down on the orange battery clip to release the battery.
    FixBot'a Sor
    Yorum Ekle
  3. GATEWAY NE56R09u  Wireless Card Replacement: adım 3, 1 resimden 1.
    • Lift the battery from the back casing to remove it.
    FixBot'a Sor
    Yorum Ekle
  4. GATEWAY NE56R09u  Wireless Card Replacement, Wireless card: adım 4, 1 resimden 1.
    • Next, using the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the wireless card.
    FixBot'a Sor
    Yorum Ekle
  5. GATEWAY NE56R09u  Wireless Card Replacement: adım 5, 1 resimden 1.
    • Once the cover is off, locate the wireless card.
    FixBot'a Sor
    Yorum Ekle
  6. GATEWAY NE56R09u  Wireless Card Replacement: adım 6, 1 resimden 1.
    • When located, remove the black and white cables from the wireless card. These are main and auxiliary antenna câbles.
    FixBot'a Sor
    Yorum Ekle
  7. GATEWAY NE56R09u  Wireless Card Replacement: adım 7, 1 resimden 1.
    • Using the PH1 head from the tool kit and the adjustable screwdriver, remove the M3x5.0mm screw with that is keeping the wireless card intact.
    FixBot'a Sor
    Yorum Ekle
  8. GATEWAY NE56R09u  Wireless Card Replacement: adım 8, 2 resimden 1. GATEWAY NE56R09u  Wireless Card Replacement: adım 8, 2 resimden 2.
    • Remove the wireless card from the laptop
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, please follow these instructions in reverse order.
Luis Cardoso
171 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G1, Peak Spring 2019 UMass Dartmouth, Team S6-G1, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G1
2 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 553
