Ana içeriğe geç
GATEWAY NE56R09u Battery Replacement
Neye ihtiyacın var
  1. GATEWAY NE56R09u Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
  2. GATEWAY NE56R09u Battery Replacement: adım 2, 1 resimden 1.
    • Using a nylon spudger or your fingers, push down on the orange battery clip to release the battery.
  3. GATEWAY NE56R09u Battery Replacement: adım 3, 1 resimden 1.
    • Finally, remove the battery by detaching it from the laptop casing. Once removed, set the battery aside and insert the new battery by lightly pushing it into the corresponding holder.
Sonuç
To insert the new battery, follow these instructions in reverse order.
joshua depina
401 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G1, Peak Spring 2019 UMass Dartmouth, Team S6-G1, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G1
2 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 235
