Ana içeriğe geç
GATEWAY NE56R09u Hard Drive Replacement
Neye ihtiyacın var
  1. GATEWAY NE56R09u Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
  2. GATEWAY NE56R09u Hard Drive Replacement: adım 2, 1 resimden 1.
    • Using a nylon spudger or your fingers, push down on the orange battery clip to release the battery.
  3. GATEWAY NE56R09u Hard Drive Replacement: adım 3, 1 resimden 1.
    • Finally, remove the battery by detaching it from the laptop casing. Once removed, set the battery aside and insert the new battery by lightly pushing it into the corresponding holder.
  4. GATEWAY NE56R09u Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Using the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the hard drive. These 2 screws are what is also keeping the hard drive in place.
  5. GATEWAY NE56R09u Hard Drive Replacement: adım 5, 1 resimden 1.
    • Push firmly down on the center of the hard drive and with a swiping to the left motion release the clip from the drive.
  6. GATEWAY NE56R09u Hard Drive Replacement: adım 6, 1 resimden 1.
    • Once the drive has been released, simple lift up the hard drive to remove it.
Sonuç
To reassemble your device, please follow these instructions in reverse order.
joshua depina
401 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G1, Peak Spring 2019 UMass Dartmouth, Team S6-G1, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G1
2 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 249
