Ana içeriğe geç
GATEWAY NE56R09u RAM Replacement
Neye ihtiyacın var
  1. GATEWAY NE56R09u RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Before you begin, make sure the laptop is turned off.
    • Flip your laptop over so the bottom is facing up.
    FixBot'a Sor
    Yorum Ekle
  2. GATEWAY NE56R09u RAM Replacement: adım 2, 1 resimden 1.
    • Using a nylon spudger or your fingers, push down on the orange battery clip to release the battery.
    FixBot'a Sor
    Yorum Ekle
  3. GATEWAY NE56R09u RAM Replacement: adım 3, 1 resimden 1.
    • Lift the battery from the back casing to remove it.
    FixBot'a Sor
    Yorum Ekle
  4. GATEWAY NE56R09u RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Locate the casing that protects the RAM modules, wireless card, and hard drive.
    FixBot'a Sor
    Yorum Ekle
  5. GATEWAY NE56R09u RAM Replacement: adım 5, 1 resimden 1.
    • With the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the RAM modules.
    FixBot'a Sor
    Yorum Ekle
  6. GATEWAY NE56R09u RAM Replacement: adım 6, 1 resimden 1.
    • On each RAM module there are two silver latches holding them in place
    • Release the latches to be able to remove the RAM module.
    FixBot'a Sor
    Yorum Ekle
  7. GATEWAY NE56R09u RAM Replacement: adım 7, 1 resimden 1.
    • Remove the RAM modules from their respected slots.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, please follow these instructions in reverse order.
joshua depina
401 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G1, Peak Spring 2019 UMass Dartmouth, Team S6-G1, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G1
2 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 24
Her zaman: 522
